If settings have been set under the Voukoder-> Configure tab, but something has been changed in the Audio/Video tab, then all the settings under Configure are reset
Parameter resets to default
It does not even have to be changed in the other tabs, the settings in the Voukoder-> Configure Tab are always back to standard, as soon as the Configure window is opened again
Kleinrotti
29. März 2019 um 19:37 Hat den Titel des Themas von „Parameter zurückgesetzt“ zu „Parameter resets to default“ geändert. -
Are these missing settings in dropdown boxes in the configure dialog?
Do other types of settings work? i.e. numeric values?
29. März 2019 um 23:03 Hat das Label In Bearbeitung hinzugefügt. -
Still happening after render completed and reopening configure menu, in beta2.
- I click on "Configure"
- I select video encoder "NVENC h.264"
- I click on the "Video" section and change to "Quantizer" 15
- I click on "Okay" and the Configure dialog closes
- I click on "Configure" again -> "NVENC h.264" is still selected and "Quantizer" 15 is still set.
Looks okay. What do I do wrong?
I dont see NVENC so I haven't tested if same happens there, but I can say that this happens with x264 AFTER render is completed and you go back to configure settings.
I can confirm that
Please re-test with 2.0-beta3 and if it is still there write the exact steps on how to reproduce it.
I aggree with this requirement :
All settings must be recorder from session to session.
It is very annoying to have to ré-enter settings each time.
This is not the case with standard settings in Premiere, all are retained from session to session
Olivier
Can someone make a small video showing the steps and final issue, please?
Made a video which shows that settings are lost after closing and reopening the Configure Tab, same if profile saved under Premiere.
Alright, let me guess: This happens with x264 and x265 only?
Fixed in 2.0-beta3.
3. April 2019 um 20:17 Hat das Label von In Bearbeitung auf Behoben geändert. -
Settings which are set for fdk aac are still resetting. r2 beta4
Can not reproduce it. Please tell me the exact steps or recorde a video of it again.
Here is a recorded video. I had reset Voukoder R2 before.
Fixed in 2.0-beta5.
