Uncompressed PCM's have bit-depth selection on "Audio encoder" drop-down menu and FLAC has it under Audio tab under "Sample format".
Audio encoder selection inconsistent
FFmpeg / libav differentiates between encoders and sample formats here. Well, it does not encode anything, but this is how it is implemented.
- "Uncompressed PCM 16bit" is an encoder with the sample format "s16"
- "Uncompressed PCM 24bit" is an encoder with the sample format "s32"
- "Uncompressed PCM 32bit" is an encoder with the sample format "s32"
I tried to make it simple some time ago, but it is too much effort and making the code too complicated.
30. März 2019 um 11:59 Hat das Label Abgewiesen hinzugefügt. -
23. Februar 2022 um 13:11 Hat das Thema aus dem Forum Feature requests nach Closed feature requests verschoben.
