Video Height and Width --- Not linkable.
  • Your default Width and Height is 320x240, When I try to change height to 1080, it retruns "The frame size is not supported" error.
    It's related with Adobe's Link-Width-and-Height function, when I click this button and changed it to "not linked", it then can edit freely.
  • Also my screenshots proved another thing: some of your value in translation files is not needed, whatever you set this value, it will be override with Adobe's translation.
    At least I found these:
    ui.premiere.tab.video
    ui.premiere.tab.video.match_source._label
    ui.premiere.tab.video.match_source._description
  • Vouk 6. April 2019 um 07:34
  • I'm using CC2018 and I didn't tried on other version yet.
    1, Open Adobe Media Encoder.
    2, Preset -> Create Encoding Preset
    3, Select Voukoder R2
    4, Go to Voukoder Tab, Configure it to ANY option, at least supporting 1080p (e.g. libx264, YUV420, High 4.2, CRF 23, and leave other to default)
    5, Save configuration and go back to "Video" Tab
    6, Now there's already an bug: it is set in 320x240, but in summary it's still 0x0.
    7, note in the option panel, the default status is "linking"
    8, then edit the height to 1080, and it occurs.
    P.S. to prove it's not related with "the frame size can't be a float number", I also tried change it to 480 but it still occurs.
  • So I can predict why it occurs:
    1, you don't have the default value, so AME thought it's 0x0.
    2, the "link" function is based on keep the width/height ratio at a constant value (as the description of the button says).
    3, as everyone knows, 0 cannot divide 0.
    4, so the "current" ratio doesn't exist.
    5, so whatever I change the height, it can't calculate the width.
    But I don't know why it displays 320x240 as default although it's 0x0.
  • Vouk 8. April 2019 um 06:42
