Ability to match source colors
  • I know this isn't a big deal. It just makes more work for me having to check if the source is using full colors or limited. I was wondering why a output of mine was really dark and figured out it was because of using full colors instead of limited.
    Could we have it auto select it if you check a box next to those options or is that not possible for it to tell if the source is limited or full etc?
    Einmal editiert, zuletzt von nikossnyder (7. April 2019 um 01:21)
  • Vouk 7. April 2019 um 08:21
    Hat das Label Abgewiesen hinzugefügt.
