AMD Threadripper Encoding Guide
  • AMD Threadripper Encoding Guide
    General settings to improve encoding speed
    • Ensure that you have the newest drivers installed for your GPU, CPU and Chipset
    • Set Memory Access Mode to Distributed in Ryzen Master (UMA)
    • For new generation Threadrippers disabling Dynamic Local Mode in Ryzen Master could improve encoding speed
    • For high performance CPU's with many cores like AMD Threadrippers or Intel Xeons there is a high chance that disabling CUDA in Premiere/Media Encoder speeds up the process, except if you have a lot of effects applied which can be rendered by the GPU (also if you export in x264 or x265)
    • Ensure that your maximum CPU power is set to 100% in the Windows-Powerplan
    • Ensure that Premiere/Media Encoder has much RAM as possible
    • I recommend to use a SSD, especially for large video files or exports
    Encoder specific settings
    VP8/VP9
    • Disable a few cores in Ryzen Master (VP8 and VP9 using only a few cores)
    • To reach faster encoding times then, you can clock the other cores higher
    Sample encoding times with a Threadripper 1950X
    Environment:
    • Windows 10 1803
    • Adobe Premiere CC 2018 12.1 (CUDA disabled)
    • Voukoder R2 2.0.5
    • AMD Threadripper 1950X @3.7 Ghz (Memory Mode Distributed, all cores enabled)
    • 32 Gig RAM (Quad Channel)
    • Geforce GTX 1080 Ti
    NVENC H.264
    Full-HD UHD
    Export settings preset=slow qp=15 b=15000000 gpu=0 maxrate=20000000
    preset=slow profile=high rc=vbr
    Video resolution 1080p 2160p
    Video length 10 min 10 min
    Video Framerate 30 FPS 60 FPS
    Avg. FPS (export) 430 FPS 95 FPS
    Export time 50 sec 6:20 min
    x264
    Full-HD UHD
    Export settings b=8000000 preset=medium profile=high rc=abr b=15000000 preset=medium profile=high rc=abr
    Avg. CPU Usage 80% 84%
    Export time 2:45 min 16:10 min
    Is your export slow?
    Check the Taskmanager while exporting and look for CPU, GPU and RAM usage.
    • Is your CPU/GPU load only at a few percent?
    When using nvenc check the FPS while exporting
    • Type this in a command line window: "c:\Program Files\NVIDIA Corporation\NVSMI\nvidia-smi.exe" encodersessions
    After exporting check the Voukoder log and look at the render times (first ones in the log)
    • If you have very high values like 20000 µs all the time there could be something wrong (some peaks are normal) or CUDA is enabled and the GPU is not used
    • If you have a lot of effects applied the render times can be very high too, but this is normal
    If you think that your export is too slow and some of these points apply, check the forum for existing topics or create a new one and explain exactly as you can.
    3 Mal editiert, zuletzt von Kleinrotti (20. August 2019 um 17:58)
  • Disabling CUDA IS an bad idea! Filtering etc. in Premiere/AME is done by the GPU, encoding is done by the video engine. Since both are parts of the graphics card they use different resources on it. You can use "GPU-Z" to verify this.
  • In general this is right yes, but if you if a high core count system like a TR1950X disabling Cuda will speed up frame rendering time. I have tested a lot of conditions and only if I apply many effects like color correction, blur effects or other filters, rendering with cuda is faster. If your project hasn't many effects disabling cuda speeds up the rendering (in the voukoder log you can also see that rendering with cuda enabled causes very high latencies because copying the frame to the gpu takes time).
