Immediate Error using NVENC using either HEVC or h.264 when selecting 10bit under the Voukoder
  • I get the following error in Adobe Media Encoder when exporting with NVENC in HEVC but only if I select the 10bit option under the Voukoder menu. If I select 8bit I don't get the error and the file encodes fine....
    xport Error
    Error compiling movie.
    Export Error
    Exporter returned bad result.
    Writing with exporter: Voukoder R2
    Writing to file: E:\04-28-19 06 Phx Rising vs Classic SC_8.mp4
    Around timecode: 00;00;00;02
    Component: Voukoder R2 of type Exporter
    Selector: 9
    Error code: -2147483648
    Someone suggested I check my video card: I am running a Titan RTX which does support 10bit NVENC.
  • Ok I tested it and I can reproduce that problem when using color range full (0-255), with limited color range it works.
    [17:48:24] Opening codec: hevc_nvenc with options: b=10000000,gpu=0,preset=slow,rc=vbr
    [17:48:24] Opening codec: aac with options: b=96000,profile=aac_low
    [17:48:24] Requesting pixel format: p010le
    [17:48:24] Encoding loop finished (Code: -2147483648)
    [17:48:24] Closing encoders ...
  • Vouk 3. Mai 2019 um 17:59
  • Vouk 3. Mai 2019 um 22:01
