Some observations regarding VBR 2 pass coding
  • Hi there!
    Just a few words regarding: the volumen of the video made by the VBR 2 pass coding sometimes is significantly less then made by CBR coding. I don't know why...:huh: Comparing with the classical H264 system coder, is less, too. For example: CBR final result - 96 Mb, VBR 2 pass - 67 Mb. The same initial video!
    Logs will be provided later.
    That's what 2 pass (VBR) is for and why you normally choose 2 pass. It first analyses the video for its visual complexity and then adjusts the required bitrate for it. So you can save some filesize. This is not a bug, it is good!
    Just like one user said: "I don't like using CRF, I can't reach my usual bitrate with it." ;)
  • Vouk 9. Mai 2019 um 20:20
    Hat das Label 2.0 hinzugefügt.
