Encoding Failed
  • Hi,
    I use the latest version (2.0.8) and get immediately quit, the log are below:
    - Encoding Time: 00:00:08
    06/08/2019 08:57:59 PM : Encoding Failed
    Export Error
    Error compiling movie.
    Export Error
    Exporter returned bad result.
    Writing with exporter: Voukoder R2
    Writing to file: C:\Users\erio\Desktop\GOPR0459_1.mp4
    Around timecode: 00:00:01:03 - 00:00:01:05
    Component: Voukoder R2 of type Exporter
    Selector: 9
    Error code: -2147483648
    I have no error on using the version 1, I try to re-render my movie and failed.
    I use IRIS PRO 6300 with all voukoder default settings. I hope you can solve my problem. Thank you and have a nice weekend.
    Erio
  • [17:19:13] Voukoder 2.0.8
    [17:19:13] by Daniel Stankewitz
    [17:19:13] ---------------------------------------------
    [17:19:13] Intel(R) Xeon(R) CPU E3-1285L v4 @ 3.40GHz
    [17:19:13] 8 logical cores
    [17:19:13] 32642 MB system memory
    [17:19:13] Display #0 on: Intel(R) Iris(TM) Pro Graphics P6300
    [17:19:13] Plugin running in Premiere Pro 13.1.2
    [17:21:05] Loading: filters/stereowiden.json
    [17:21:05] Loading: filters/superequalizer.json
    [17:21:05] Loading: filters/surround.json
    [17:21:05] Loading: filters/treble.json
    [17:21:05] Loading: filters/tremolo.json
    [17:21:05] Loading: filters/vibrato.json
    [17:21:05] Loading: filters/volume.json
    [17:26:14] Opening codec: libx265 with options: preset=veryslow
    [17:26:14] Opening codec: aac with options: b=320000|profile=aac_main
    [17:26:17] Requesting pixel format: yuv420p
    [17:26:18]
    [17:26:18] Exported 1 frames in 0 seconds. (avg. 2 fps)
    [17:26:18] Encoding loop finished (Code: -2147483648)
    [17:26:18] Closing encoders ...
  • Arr..... When I try to export video only, it works. Seems the problem is on the audio. I change them from AAC to whatever but just failed.
    I use the native HEVC without problem (but slow).
  • Most of the video captured by GoPro 5, Audio bit rate is 128kbps, Stereo, sample rate is 48kHz.
    Once I think the bit rate is too high I set (320), or also the sample rate, so I set it lower to 128, 44.1 but no luck. (Or set 320, 96, also no luck.) For the encoder AAC, FLAC, MP3 all failed.
    Everything works in generic HEVC from adobe.
  • Vouk 14. Juni 2019 um 07:28
  • Hi Vouk,
    Appreciated with your follow up. That's strange if I use the same project file, with the built-in audio encoder, it works but it doesn't work with Voukoder.
  • Sorry for the late reply. I try the same way as you did, copy the entire project to a new one but no luck!
    I start a new project, copy the entire sequence to the new one, let it generate preview again, and stabilizing again, but still failed.
    - Encoding Time: 00:01:27
    06/23/2019 08:28:21 PM : Encoding Failed
    Export Error
    Export Error
    Writing to file: D:\PSSD\VIDEOS\TAIPEI2018\Header\PAPA.mp4
    Around timecode: 00;00;01;03
    Selector: 9
  • Did you find the problem? Im here with the same issue now
