Hello everyone !
I think it will be great idea if You post here Your best settings for exporting in Premiere Pro with VOUKODER.
Let's start with NVENC h264 for
1080p 25fps
1080p 50fps
and 4k variations also.
Export settings & presets
Paul St. -
11. Juni 2019 um 11:57
Feel free to participate here: As a user I want to have easy to use presets for each encoder available to use.
Meanwhile I also prefer the Handbrake style approach.
Don't define presets by some settings, define them per use-case (i.e. "YouTube Recommenended", "YouTube GPU accelerated") Just some quick thoughts
Wanted - 4k ultrawide 60 fps best quality possible for youtube.
Hello all.
I usually record youtube game footage with Shadowplay but decided to try SLOBE (obs) with nevec new codec. When i bring this into premier and have installed the polug in, I have NO ide what settings to export, there are so many options.
Basically i usually export out of premier at 130,000k bit rate to maintian quality oin youtube.
Can somebody show or create a preset so i know what settings to use, my last atemp made a 180 gig file for a 5 min video!!
Any help appreciated
6. September 2019 um 09:32 Hat das Label Adobe Premiere hinzugefügt. -
Anyone can explain what is every preset option is?
