The aim is to support all "extra commands" as advance settings in the voukoder GUI. And as far as i can tell all of the are supported already.
4:4:4 10 bit is supported with x265. But currently only YUV and not RGB. libx264_rgb is internally already available. But does it really make sense to export h264 in rgb in Premiere? It would make sense for AE, yes. But you're using premiere, right?
