Adding more pixel formats for nvenc
  • Currently it is not possible to select a pixel format for h264_nvenc.
    The ffmpeg help output says these are available:
    Supported pixel formats: yuv420p nv12 p010le yuv444p p016le yuv444p16le bgr0 rgb0 cuda d3d11
    If you choose hevc_nvenc it is only possible to select 8 or 10 Bit but no pixel format.
    These are available for hevc_nvenc:
  • Vouk 19. August 2019 um 10:56
    Hat das Label von wcf.acp.label.label6 auf Prüfung geändert.
