I got an error encoding a file Premiere Pro queue with AME (v. 13.1.3)
AMEEncodingErrorLog.txt
- Encoding Time: 00:00:13
08/28/2019 06:44:17 PM : Encoding Failed
Adobe Media Encoder
The destination sample rate is different from the source sample rate. Resampling changes the signal's loudness and true peak level.
Voukoder R2
Unable to initialize the encoder.
This has most likely to do with an invalid combination of options.
Export Error
Exporter returned bad result.
Writing with exporter: Voukoder R2
Writing to file: U:\LUCKY & ME\MP4\Lucky&Me Touché.mp4
Around timecode: 00:00:00:00
Component: Voukoder R2 of type Exporter
Selector: 9
Error code: 20
I reset the encoding one more time but the error was there.
So my next guess was the filename.
So I was very lucky. After changing é -> e the error was gone.
(to vouk: filename path was changed from it's original path, but for whatever reason you can't reproduce it, I can pm you)
