• Vouk 10. September 2019 um 09:54
    The issue is that Premiere / Voukoder was not able to identify the framerate "23,932" fps. I guess this is some sort of a variable frame rate (VFR) and is most likely (24000/1001fps or 24fps) material.
    Can you please post a MediaInfo of the source file?
    The solution is to set an FPS value manually.
  • Vouk 22. März 2020 um 12:19
    Hat das Label von In Bearbeitung auf Kein Bug geändert.
