Hello,
two things i noticed for the audio codecs in Vegas Pro 15.
1. Unable to open audio encoder: flac
When i try to encode with flac, the encoding process is instantly closing. I tried different video codecs with default settings, but i can only encode without flac.
This is the output from the log:
[13:40:28] Opening codec: libx264 with options:
[13:40:28] Opening codec: flac with options:
[13:40:28] Failed opening codec: flac
[13:40:28] Unable to open audio encoder: flac
[13:40:28] Closing encoders ...
2. ACC and Vorbis don't save settings
- When i use AAC as audio encoder the bitrate always resets to 96 kbit/s (default), even when i try to save it as a template
- Same thing for Vorbis with "Constant Quality" strategy. The "Average Bitrate" strategy will be saved correctly.
