Hi Vouk,
Just testing the new 2.3 beta 3 on MAGIX Vegas Pro 14 and 15.
I was wondering if you could please add the option to select/specify the audio sample rates (48000, 44100, 32000, etc) for the audio encoders.
Thank you.
Hi Vouk,
Thank you.
Normally this selection should be taken from the projects settings. Can you please try changing it in the projects settings.
Fixed taking this value from the project settings.
Hi
Wanted to try the fixed voukoder 2.3beta4 but the VEGAS PRO connector installer vegas-connector-0.3.0.msi cant be installed. Says a DLL is missing. The AfterEffects and Premiere connectors install just fine.
I'm on Windows 10 Pro x64..
