With the latest builds of Voukoder there is no video data in the rendered MP4 file, it's audio only. Selected x264 as video codec (CRF set to 20 and level range set to PC/Full Levels) and AAC (settings untouched) as audio codec.
VP17 - Voukoder renders audio only
MajorBubble -
22. November 2019 um 14:17
Do you use the "color space" filter? There is a known issue that you have to set all options of one group (i.e. output), not just a single one.
Yes, I did and that was it. It now renders video, too. Thanks for that hint.
Now there's a level problem, but I have to further investigate this one.
24. November 2019 um 00:03 Hat das Label Behoben hinzugefügt. -
Same thing for the Scale (Z-Lib) filter, when i use:
Width
Height
Filter
When using the Scale (Z-Lib) filter the problem still exists, with 2.3beta6 and vegas-connector-0.4.5
Fixed!
Still the same problem in the 2.3beta7
Well, it's working on my side. Can you send a log file?
Anbei der Log.
Seems there has been a change in zlib that is not compatible with ffmpeg git master:
code 2049: unrecognized chroma location
Error while filtering: Generic error in an external library
Failed to inject frame into filter network: Generic error in an external library
Error while processing the decoded data for stream #0:0
Please try 2.3rc1.
2.3rc1 is working. Thank you!
