Voukoder 2.2 not working in AE 2020
  • Hi,
    I am using After Effects 2020 and rendering with Voukoder is not working. I can render with built-in options but not with Voukoder. Here's the log file:
    [21:37:15] Voukoder 2.2.0
    [21:37:15] by Daniel Stankewitz
    [21:37:15] ---------------------------------------------
    [21:37:15] AMD Ryzen 5 2400G with Radeon Vega Graphics
    [21:37:15] 8 logical cores
    [21:37:15] 14284 MB system memory
    [21:37:15] Display #0 on: AMD Radeon(TM) RX Vega 11 Graphics
    [21:37:15] Loading: translations/english.json
    [21:37:15] Loading: translations/german.json
    [21:37:15] Loading: translations/french.json
    [21:37:15] Loading: encoders/dca.json
    [21:37:15] Loading: encoders/eac3.json
    [21:37:15] Loading: encoders/truehd.json
    [21:37:15] Loading: encoders/aac.json
    [21:37:15] Loading: encoders/ac3.json
    [21:37:15] Loading: encoders/alac.json
    [21:37:15] Loading: encoders/ffv1.json
    [21:37:15] Loading: encoders/flac.json
    [21:37:15] Loading: encoders/h264_amf.json
    [21:37:15] Loading: encoders/h264_nvenc.json
    [21:37:15] Unloading: encoders/h264_nvenc.json
    [21:37:15] Loading: encoders/hevc_amf.json
    [21:37:15] Loading: encoders/hevc_nvenc.json
    [21:37:15] Unloading: encoders/hevc_nvenc.json
    [21:37:15] Loading: encoders/libfdk_aac.json
    [21:37:15] Unloading: encoders/libfdk_aac.json
    [21:37:15] Loading: encoders/libmp3lame.json
    [21:37:15] Loading: encoders/libopus.json
    [21:37:15] Loading: encoders/libvorbis.json
    [21:37:15] Loading: encoders/libvpx.json
    [21:37:15] Loading: encoders/libvpx-vp9.json
    [21:37:15] Loading: encoders/libx264.json
    [21:37:15] Loading: encoders/libx265.json
    [21:37:16] Loading: encoders/pcm_s16le.json
    [21:37:16] Loading: encoders/pcm_s24le.json
    [21:37:16] Loading: encoders/pcm_s32le.json
    [21:37:16] Loading: encoders/prores_ks.json
    [21:37:16] Loading: encoders/hap.json
    [21:37:16] Loading: encoders/h264_qsv.json
    [21:37:16] Unloading: encoders/h264_qsv.json
    [21:37:16] Loading: encoders/hevc_qsv.json
    [21:37:16] Unloading: encoders/hevc_qsv.json
    [21:37:16] Loading: encoders/libsvt_av1.json
    [21:37:16] Unloading: encoders/libsvt_av1.json
    [21:37:16] Loading: muxers/matroska.json
    [21:37:16] Loading: muxers/mov.json
    [21:37:16] Loading: muxers/mp4.json
    [21:37:16] Loading: muxers/webm.json
    [21:37:16] Loading: muxers/mp3.json
    [21:37:16] Loading: muxers/opus.json
    [21:37:16] Loading: muxers/ogg.json
    [21:37:16] Loading: muxers/flac.json
    [21:37:16] Loading: muxers/adts.json
    [21:37:16] Loading: muxers/wav.json
    [21:37:16] Loading: muxers/h264.json
    [21:37:16] Loading: muxers/hevc.json
    [21:37:16] Loading: muxers/mpeg2video.json
    [21:37:16] Loading: muxers/mpegts.json
    [21:37:16] Loading: filters/bwdif.json
    [21:37:16] Loading: filters/unsharp.json
    [21:37:16] Loading: filters/yadif.json
    [21:37:16] Loading: filters/zscale.json
    [21:37:44] Opening codec: libx265 with options:
    [21:37:44] Failed opening codec: libx265
    [21:37:44] Unable to open video encoder: libx265
    [21:37:44] Closing encoders ...
    [21:37:44] Unable to open the encoder engine with the supplied export info.
    [21:38:11] Opening codec: hevc_amf with options:
    [21:38:11] Failed opening codec: hevc_amf
    [21:38:11] Unable to open video encoder: hevc_amf
    [21:38:11] Closing encoders ...
    [21:38:11] Unable to open the encoder engine with the supplied export info.
  • nasif123 26. November 2019 um 16:43
    Hat den Titel des Themas von „Voukoder not working in AE 2020“ zu „Voukoder 2.2 not working in AE 2020“ geändert.
  • Log file from Adobe Media Encoder:
    - Encoding Time: 00:00:00
    11/26/2019 09:46:01 PM : Encoding Failed
    Export Error
    Error compiling movie.
    Export Error
    Exporter returned bad result.
    Writing with exporter: Voukoder R2
    Writing to file: D:\Junk\Comp 1_1.mp4
    Component: Voukoder R2 of type Exporter
    Selector: 14
    Error code: 20
  • Vouk 28. November 2019 um 15:31
