Hi,
I'm using the latest Voucoder 2.3 with the After Effects Connector 0.9.3. When I add a rendering job via "Add to Render Queue" inside After Effects, and select a x264 with two-pass, the encoding stops at the first pass. No second pass is done, and no eventual file is created. See log file below. One pass x264 render in After Effects works fine.
If I choose "Add to Adobe Media Encoder Queue", the x264 two pass render works. I think the difference is because Adobe Media Encoder appears to be using the Adobe Premiere Connector.
[23:00:37] =============================================
[23:00:37] Voukoder 2.3 (2.3.0)
[23:00:37] by Daniel Stankewitz
[23:00:37] ---------------------------------------------
[23:00:37] AMD Ryzen 9 3900X 12-Core Processor
[23:00:37] 24 logical cores
[23:00:37] 65484 MB system memory
[23:00:37] Display #0 on: NVIDIA GeForce RTX 2070 SUPER
[23:00:37] Loading: translations/english.json
[23:00:37] Loading: translations/german.json
[23:00:37] Loading: translations/french.json
[23:00:37] Loading: encoders/dca.json
[23:00:37] Loading: encoders/eac3.json
[23:00:37] Loading: encoders/truehd.json
[23:00:37] Loading: encoders/aac.json
[23:00:37] Loading: encoders/ac3.json
[23:00:37] Loading: encoders/alac.json
[23:00:37] Loading: encoders/ffv1.json
[23:00:37] Loading: encoders/flac.json
[23:00:37] Loading: encoders/h264_amf.json
[23:00:37] Unloading: encoders/h264_amf.json
[23:00:37] Loading: encoders/h264_nvenc.json
[23:00:37] Loading: encoders/hevc_amf.json
[23:00:37] Unloading: encoders/hevc_amf.json
[23:00:37] Loading: encoders/hevc_nvenc.json
[23:00:37] Loading: encoders/libfdk_aac.json
[23:00:37] Unloading: encoders/libfdk_aac.json
[23:00:37] Loading: encoders/libmp3lame.json
[23:00:37] Loading: encoders/libopus.json
[23:00:37] Loading: encoders/libvorbis.json
[23:00:37] Loading: encoders/libvpx.json
[23:00:37] Loading: encoders/libvpx-vp9.json
[23:00:37] Loading: encoders/libx264.json
[23:00:37] Loading: encoders/libx265.json
[23:00:37] Loading: encoders/pcm_s16le.json
[23:00:37] Loading: encoders/pcm_s24le.json
[23:00:37] Loading: encoders/pcm_s32le.json
[23:00:37] Loading: encoders/prores_ks.json
[23:00:37] Loading: encoders/hap.json
[23:00:37] Loading: encoders/h264_qsv.json
[23:00:37] Unloading: encoders/h264_qsv.json
[23:00:37] Loading: encoders/hevc_qsv.json
[23:00:37] Unloading: encoders/hevc_qsv.json
[23:00:37] Loading: encoders/libsvt_av1.json
[23:00:37] Unloading: encoders/libsvt_av1.json
[23:00:37] Loading: encoders/libsvt_hevc.json
[23:00:37] Unloading: encoders/libsvt_hevc.json
[23:00:37] Loading: encoders/vp9_qsv.json
[23:00:37] Unloading: encoders/vp9_qsv.json
[23:00:37] Loading: muxers/matroska.json
[23:00:37] Loading: muxers/mov.json
[23:00:37] Loading: muxers/mp4.json
[23:00:37] Loading: muxers/webm.json
[23:00:37] Loading: muxers/mp3.json
[23:00:37] Loading: muxers/opus.json
[23:00:37] Loading: muxers/ogg.json
[23:00:37] Loading: muxers/flac.json
[23:00:37] Loading: muxers/adts.json
[23:00:37] Loading: muxers/wav.json
[23:00:37] Loading: muxers/h264.json
[23:00:37] Loading: muxers/hevc.json
[23:00:37] Loading: muxers/mpeg2video.json
[23:00:37] Loading: muxers/mpegts.json
[23:00:37] Loading: filters/bwdif.json
[23:00:37] Loading: filters/colorspace.json
[23:00:37] Loading: filters/eq.json
[23:00:37] Loading: filters/setparams.json
[23:00:37] Loading: filters/unsharp.json
[23:00:37] Loading: filters/yadif.json
[23:00:37] Loading: filters/zscale.json
[23:00:58] ---------------------------------------------
[23:00:58] Export started
[23:00:58] Filename: E:\Special Projects\Comp 1.mp4
[23:00:58] Application: Voukoder (Voukoder)
[23:00:58] Passes: 2
[23:00:58] - Video -------------------------------------
[23:00:58] Frame size: 1920x1080
[23:00:58] Pixel aspect: 1:1
[23:00:58] Timebase: 65536/1638400 (25.00 fps)
[23:00:58] Interlaced: No
[23:00:58] Encoder: libx264
[23:00:58] Options: _2pass=1 _pixelFormat=yuv420p b=10000000 preset=medium profile=main rc=abr slow-firstpass=0 tune=film
[23:00:58] Side data:
[23:00:58] Filters:
[23:00:58] Color range: unknown
[23:00:58] Color space: unknown
[23:00:58] Color primaries: unknown
[23:00:58] Color transfer: unknown
[23:00:58] Running pass #1 ...
[23:00:58] Using pass logfile: C:\Users\Rainbow\AppData\Local\Temp\vouF15A.tmp
[23:00:58] Opening codec: libx264 with options: b=10000000|preset=medium|profile=main|rc=abr|slow-firstpass=0|tune=film
[23:00:58] Applying video filters: format=pix_fmts=yuv420p
[23:00:58] Frame #0: vRender: 16009 us, vProcess: 0 us, vEncoding: 20772 us, Latency: 36781 us
[23:00:58] Frame #1: vRender: 14317 us, vProcess: 0 us, vEncoding: 10380 us, Latency: 24698 us
[23:00:58] Frame #2: vRender: 14092 us, vProcess: 0 us, vEncoding: 10591 us, Latency: 24683 us
[23:00:58] Frame #3: vRender: 14041 us, vProcess: 0 us, vEncoding: 10158 us, Latency: 24199 us
[23:00:58] Frame #4: vRender: 13731 us, vProcess: 0 us, vEncoding: 10309 us, Latency: 24041 us
[23:00:58] Frame #5: vRender: 15260 us, vProcess: 0 us, vEncoding: 10725 us, Latency: 25985 us
[23:00:58] Frame #6: vRender: 13787 us, vProcess: 0 us, vEncoding: 10105 us, Latency: 23892 us
[23:00:58] Frame #7: vRender: 13893 us, vProcess: 0 us, vEncoding: 10663 us, Latency: 24556 us
[23:00:58] Frame #8: vRender: 13818 us, vProcess: 0 us, vEncoding: 10002 us, Latency: 23820 us
[23:00:58] Frame #9: vRender: 13767 us, vProcess: 0 us, vEncoding: 10339 us, Latency: 24107 us
[23:00:58] Frame #10: vRender: 13894 us, vProcess: 0 us, vEncoding: 10754 us, Latency: 24649 us
[23:00:58] Frame #11: vRender: 13599 us, vProcess: 0 us, vEncoding: 9942 us, Latency: 23542 us
[23:00:58] Frame #12: vRender: 13721 us, vProcess: 0 us, vEncoding: 10192 us, Latency: 23914 us
[23:00:58] Frame #13: vRender: 14172 us, vProcess: 0 us, vEncoding: 10007 us, Latency: 24180 us
[23:00:58] Frame #14: vRender: 17945 us, vProcess: 0 us, vEncoding: 10832 us, Latency: 28777 us
[23:00:58] Frame #15: vRender: 14294 us, vProcess: 0 us, vEncoding: 9959 us, Latency: 24253 us
[23:00:58] Frame #16: vRender: 13742 us, vProcess: 0 us, vEncoding: 10239 us, Latency: 23982 us
[23:00:58] Frame #17: vRender: 14564 us, vProcess: 0 us, vEncoding: 10164 us, Latency: 24728 us
[23:00:58] Frame #18: vRender: 13762 us, vProcess: 0 us, vEncoding: 10337 us, Latency: 24099 us
[23:00:58] Frame #19: vRender: 13666 us, vProcess: 0 us, vEncoding: 10693 us, Latency: 24360 us
[23:00:58] Frame #20: vRender: 13821 us, vProcess: 0 us, vEncoding: 10126 us, Latency: 23947 us
[23:00:58] Frame #21: vRender: 13843 us, vProcess: 0 us, vEncoding: 10251 us, Latency: 24094 us
[23:00:58] Frame #22: vRender: 13906 us, vProcess: 0 us, vEncoding: 10044 us, Latency: 23951 us
[23:00:58] Frame #23: vRender: 13842 us, vProcess: 0 us, vEncoding: 10233 us, Latency: 24075 us
[23:00:58] Frame #24: vRender: 14168 us, vProcess: 0 us, vEncoding: 10937 us, Latency: 25105 us
[23:00:58] Frame #25: vRender: 15873 us, vProcess: 0 us, vEncoding: 12424 us, Latency: 28298 us
[23:00:58] Frame #26: vRender: 15845 us, vProcess: 0 us, vEncoding: 10863 us, Latency: 26708 us
[23:00:58] Frame #27: vRender: 13615 us, vProcess: 0 us, vEncoding: 10043 us, Latency: 23658 us
[23:00:58] Frame #28: vRender: 13759 us, vProcess: 0 us, vEncoding: 10814 us, Latency: 24574 us
[23:00:59] Frame #29: vRender: 7438 us, vProcess: 0 us, vEncoding: 9882 us, Latency: 17320 us
[23:00:59] Frame #30: vRender: 7528 us, vProcess: 0 us, vEncoding: 10231 us, Latency: 17760 us
[23:00:59] Frame #31: vRender: 7442 us, vProcess: 0 us, vEncoding: 9994 us, Latency: 17436 us
[23:00:59] Frame #32: vRender: 7531 us, vProcess: 0 us, vEncoding: 10214 us, Latency: 17746 us
[23:00:59] Frame #33: vRender: 7452 us, vProcess: 0 us, vEncoding: 10262 us, Latency: 17715 us
[23:00:59] Frame #34: vRender: 7898 us, vProcess: 0 us, vEncoding: 10739 us, Latency: 18637 us
[23:00:59] Frame #35: vRender: 7641 us, vProcess: 0 us, vEncoding: 10046 us, Latency: 17687 us
[23:00:59] Frame #36: vRender: 7556 us, vProcess: 0 us, vEncoding: 10307 us, Latency: 17864 us
[23:00:59] Frame #37: vRender: 7589 us, vProcess: 0 us, vEncoding: 10168 us, Latency: 17758 us
[23:00:59] Frame #38: vRender: 7673 us, vProcess: 0 us, vEncoding: 10413 us, Latency: 18087 us
[23:00:59] Frame #39: vRender: 7685 us, vProcess: 0 us, vEncoding: 10064 us, Latency: 17749 us
[23:00:59] Frame #40: vRender: 7973 us, vProcess: 0 us, vEncoding: 10694 us, Latency: 18667 us
[23:00:59] Frame #41: vRender: 7640 us, vProcess: 0 us, vEncoding: 10098 us, Latency: 17739 us
[23:00:59] Frame #42: vRender: 7935 us, vProcess: 0 us, vEncoding: 10985 us, Latency: 18921 us
[23:00:59] Frame #43: vRender: 8236 us, vProcess: 0 us, vEncoding: 11402 us, Latency: 19638 us
[23:00:59] Frame #44: vRender: 7731 us, vProcess: 0 us, vEncoding: 10195 us, Latency: 17926 us
[23:00:59] Frame #45: vRender: 7569 us, vProcess: 0 us, vEncoding: 10400 us, Latency: 17970 us
[23:00:59] Frame #46: vRender: 7970 us, vProcess: 0 us, vEncoding: 11270 us, Latency: 19241 us
[23:00:59] Frame #47: vRender: 8173 us, vProcess: 0 us, vEncoding: 10492 us, Latency: 18665 us
[23:00:59] Frame #48: vRender: 8193 us, vProcess: 0 us, vEncoding: 10843 us, Latency: 19036 us
[23:00:59] Frame #49: vRender: 8200 us, vProcess: 0 us, vEncoding: 10500 us, Latency: 18701 us
[23:00:59] Frame #50: vRender: 7928 us, vProcess: 0 us, vEncoding: 10476 us, Latency: 18404 us
[23:00:59] Frame #51: vRender: 7897 us, vProcess: 0 us, vEncoding: 10534 us, Latency: 18432 us
[23:00:59] Exported 52 frames in 1 seconds. (avg. 45 fps)
[23:00:59] Flushing encoders and finalizing ...
[23:00:59] Video and audio buffers flushed.
[23:00:59] Trailer has been written.
[23:00:59] Closing encoders ...
[23:00:59] ---------------------------------------------
[23:00:59] Export finished
