Voukoder and interlaced DV content Adobe Premiere 2019/2020
  • When I try to convert (h.264,h.265,NVENC or not) my DV PAL through Vouck, it just closing export page when I press "export"..Work when I swich to 50p, no fields...It works fast, but picture is stay little blurie on same bitrate.Native x264 Adobe Premiere looks beter. ..Why that& h.264, can work with fields correctly.
  • 00:53:49] =============================================
    [00:53:49] Voukoder 3 (3.0.0)
    [00:53:49] by Daniel Stankewitz
    [00:53:49] ---------------------------------------------
    [00:53:49] AMD Ryzen 7 3700X 8-Core Processor
    [00:53:49] 16 logical cores
    [00:53:49] 16333 MB system memory
    [00:53:49] Display #0 on: NVIDIA GeForce RTX 2070 SUPER
    [00:53:49] Export started
    [00:53:49] Filename: D:\Video4\newDV2\саша выпуск.mp4
    [00:53:49] Application: Voukoder (Adobe Premiere)
    [00:53:49] Passes: 1
    [00:53:49] - Video -------------------------------------
    [00:53:49] Frame size: 720x576
    [00:53:49] Pixel aspect: 768:702
    [00:53:49] Timebase: 1/25 (25.00 fps)
    [00:53:49] Interlaced: Bottom first
    [00:53:49] Encoder: hevc_nvenc
    [00:53:49] Options: _computeCapability=7.5 _pixelFormat=yuv420p b=13000000 gpu=0 preset=slow rc=cbr_hq
    [00:53:49] Side data: <none>
    [00:53:49] Filters: <none>
    [00:53:49] Color range: unknown
    [00:53:49] Color space: unknown
    [00:53:49] Color primaries: unknown
    [00:53:49] Color transfer: unknown
    [00:53:49] - Audio -------------------------------------
    [00:53:49] Timebase: 1/48000
    [00:53:49] Channels: 2
    [00:53:49] Encoder: aac
    [00:53:49] Options: _sampleFormat=fltp b=320000 profile=aac_low
    [00:53:49] Opening codec: hevc_nvenc with options: b=13000000|gpu=0|preset=slow|rc=cbr_hq
    [00:53:49] Failed opening codec: hevc_nvenc
    [00:53:49] Unable to open video encoder: hevc_nvenc
    [00:53:49] Closing encoders ...
    [00:53:49] Opening encoder failed! Aborting ...
    [00:53:49] 00000000B0FD5FD0
  • [00:53:49] =============================================
    [00:55:23] ---------------------------------------------
    [00:55:23] Export started
    [00:55:23] Filename: D:\Video4\newDV2\test.mp4
    [00:55:23] Application: Voukoder (Adobe Premiere)
    [00:55:23] Passes: 1
    [00:55:23] - Video -------------------------------------
    [00:55:23] Frame size: 720x576
    [00:55:23] Pixel aspect: 768:702
    [00:55:23] Timebase: 1/25 (25.00 fps)
    [00:55:23] Interlaced: Bottom first
    [00:55:23] Encoder: libx264
    [00:55:23] Options: _pixelFormat=yuv420p b=13000000 preset=slow rc=abr
    [00:55:23] Side data: <none>
    [00:55:23] Filters: <none>
    [00:55:23] Color range: unknown
    [00:55:23] Color space: unknown
    [00:55:23] Color primaries: unknown
    [00:55:23] Color transfer: unknown
    [00:55:23] - Audio -------------------------------------
    [00:55:23] Timebase: 1/48000
    [00:55:23] Channels: 2
    [00:55:23] Encoder: aac
    [00:55:23] Options: _sampleFormat=fltp b=320000 profile=aac_low
    [00:55:23] Opening codec: libx264 with options: b=13000000|preset=slow|rc=abr
    [00:55:23] Opening codec: aac with options: b=320000|profile=aac_low
    [00:55:23] Requesting pixel format: yuv420p
    [00:55:23] Applying audio filters: setnsamples=n=1024:p=0
    [00:55:23] Frame #0: vRender: 48612 us, vProcess: 3 us, vEncoding: 796 us, aRender: 34799 us, aEncoding: 6137 us, Latency: 90880 us
    [00:55:23] Frame #1: vRender: 8 us, vProcess: 3 us, vEncoding: 496 us, aRender: 32 us, aEncoding: 895 us, Latency: 1443 us
    [00:55:23] Frame #2: vRender: 496 us, vProcess: 1 us, vEncoding: 562 us, aRender: 16 us, aEncoding: 561 us, Latency: 1641 us
    [00:55:23] Frame #3: vRender: 4 us, vProcess: 5 us, vEncoding: 592 us, aRender: 12 us, aEncoding: 539 us, Latency: 1158 us
    [00:55:23] Frame #4: vRender: 3 us, vProcess: 1 us, vEncoding: 645 us, aRender: 20 us, aEncoding: 733 us, Latency: 1414 us
    "blablabla too big file i cut it'
    [00:55:26] Frame #223: vRender: 17 us, vProcess: 4 us, vEncoding: 37884 us, aRender: 6 us, aEncoding: 622 us, Latency: 38546 us
    [00:55:26] Frame #224: vRender: 16 us, vProcess: 4 us, vEncoding: 323 us, aRender: 1 us, aEncoding: 271 us, Latency: 622 us
    [00:55:26] Frame #225: vRender: 3 us, vProcess: 3 us, vEncoding: 326 us, aRender: 1 us, aEncoding: 574 us, Latency: 912 us
    [00:55:26] Exported 226 frames in 2 seconds. (avg. 75 fps)
    [00:55:26] Encoding loop finished (Code: 1)
    [00:55:26] Flushing encoders and finalizing ...
    [00:55:27] Video and audio buffers flushed.
    [00:55:27] Trailer has been written.
    [00:55:27] Closing encoders ...
    [00:55:27] ---------------------------------------------
    [00:55:27] Export finished
    [00:56:05] ---------------------------------------------
    [00:56:05] Export started
    [00:56:05] Filename: D:\Video4\newDV2\test.mp4
    [00:56:05] Application: Voukoder (Adobe Premiere)
    [00:56:05] Passes: 1
    [00:56:05] - Video -------------------------------------
    [00:56:05] Frame size: 720x576
    [00:56:05] Pixel aspect: 768:702
    [00:56:05] Timebase: 1/25 (25.00 fps)
    [00:56:05] Interlaced: Bottom first
    [00:56:05] Encoder: h264_nvenc
    [00:56:05] Options: _computeCapability=7.5 _pixelFormat=yuv420p b=13000000 gpu=0 preset=slow rc=cbr
    [00:56:05] Side data: <none>
    [00:56:05] Filters: <none>
    [00:56:05] Color range: unknown
    [00:56:05] Color space: unknown
    [00:56:05] Color primaries: unknown
    [00:56:05] Color transfer: unknown
    [00:56:05] - Audio -------------------------------------
    [00:56:05] Timebase: 1/48000
    [00:56:05] Channels: 2
    [00:56:05] Encoder: aac
    [00:56:05] Options: _sampleFormat=fltp b=320000 profile=aac_low
    [00:56:05] Opening codec: h264_nvenc with options: b=13000000|gpu=0|preset=slow|rc=cbr
    [00:56:05] Failed opening codec: h264_nvenc
    [00:56:05] Unable to open video encoder: h264_nvenc
    [00:56:05] Closing encoders ...
    [00:56:05] Opening encoder failed! Aborting ...
    [00:56:05] 00000000B0FD5FD0
  • Vouk 15. Februar 2020 um 07:09
  • You could deinterlace your files first and then encode it as progressive.
    720x576x50 is much blurry, because 720x288x50(25i) needs lower bitrate to encode.. I don't need to buy some on 3700x ryzen wich convert 1 hour of video for 5-7 min h.264...There are nothing in my life to decode, DV only, just because tape can die, and 25mb\s avi is too fat. That topic it is just theoretical boring thoughts ))))
