Option for 24bit TrueHD. Right now, it only outputs 16 bit. 24 bit is a little more common. And it sounds better ![]()
24bit TrueHD
- Nicht möglich
scarbrtj -
25. Februar 2020 um 09:11
Do you know if 24bit TrueHD is supported by ffmpeg?
Alles anzeigenffmpeg version N-96835-g177c68e Copyright (c) 2000-2020 the FFmpeg developers built with Microsoft (R) C/C++-Optimierungscompiler Version 19.16.27032.1 fuer x64 configuration: --toolchain=msvc --extra-cflags='-MD -I/c/TeamCity/buildAgent/work/ffmpeg_nightly_release/build/include' --extra-ldflags='-LIBPATH:/c/TeamCity/buildAgent/work/ffmpeg_nightly_release/build/lib' --prefix=/c/TeamCity/buildAgent/work/ffmpeg_nightly_release/build --pkg-config-flags=--static --disable-doc --disable-shared --enable-static --enable-runtime-cpudetect --disable-devices --disable-demuxers --disable-decoders --disable-network --enable-w32threads --enable-gpl --enable-nvenc --enable-amf --enable-libmfx --enable-libvorbis --enable-libsnappy --enable-libvpx --enable-libfdk-aac --enable-libmp3lame --enable-libzimg --enable-libx264 --enable-libopus --enable-libx265 libavutil 56. 42.100 / 56. 42.100 libavcodec 58. 73.102 / 58. 73.102 libavformat 58. 39.101 / 58. 39.101 libavdevice 58. 9.103 / 58. 9.103 libavfilter 7. 77.100 / 7. 77.100 libswscale 5. 6.100 / 5. 6.100 libswresample 3. 6.100 / 3. 6.100 libpostproc 55. 6.100 / 55. 6.100 Encoder truehd [TrueHD]: General capabilities: delay small exp Threading capabilities: none Supported sample rates: 44100 48000 88200 96000 176400 192000 Supported sample formats: s16 Supported channel layouts: stereo 5.0 5.1Unfortunately not.
25. Februar 2020 um 17:25 Hat das Label Nicht möglich hinzugefügt.
