Hi,
I am getting the following error when exporting the media. It just vanishes immediately after doing nothing.
Thanks,
Sourav
ERROR
[09:16:28] =============================================
[09:16:28] Voukoder 3 (3.0.0)
[09:16:28] by Daniel Stankewitz
[09:16:28] ---------------------------------------------
[09:16:28] Intel(R) Core(TM) i5-3450 CPU @ 3.10GHz
[09:16:28] 4 logical cores
[09:16:28] 20445 MB system memory
[09:16:28] Display #0 on: NVIDIA GeForce GTX 1650 SUPER
[09:16:28] Display #1 on: NVIDIA GeForce GTX 1650 SUPER
[09:16:28] Export started
[09:16:28] Filename: C:\MTS\2017\Sangeet Copy 01.mp4
[09:16:28] Application: Voukoder (Adobe Premiere)
[09:16:28] Passes: 1
[09:16:28] - Video -------------------------------------
[09:16:28] Frame size: 1920x1080
[09:16:28] Pixel aspect: 1:1
[09:16:28] Timebase: 1/25 (25.00 fps)
[09:16:28] Interlaced: Top first
[09:16:28] Encoder: h264_nvenc
[09:16:28] Options: _computeCapability=7.5 _pixelFormat=yuv420p gpu=0
[09:16:28] Side data: <none>
[09:16:28] Filters: <none>
[09:16:28] Color range: unknown
[09:16:28] Color space: unknown
[09:16:28] Color primaries: unknown
[09:16:28] Color transfer: unknown
[09:16:28] - Audio -------------------------------------
[09:16:28] Timebase: 1/48000
[09:16:28] Channels: 2
[09:16:28] Encoder: aac
[09:16:28] Options: _sampleFormat=fltp b=96000 profile=aac_low
[09:16:28] Opening codec: h264_nvenc with options: gpu=0
[09:16:28] Failed opening codec: h264_nvenc
[09:16:28] Unable to open video encoder: h264_nvenc
[09:16:28] Closing encoders ...
[09:16:28] Opening encoder failed! Aborting ...
[09:16:28] 00000000CC885EA0
