Voukoder 4.1 renders blurry video
  • Vouk 22. März 2020 um 10:37
    Hat das Label 4 entfernt.
    Does the file look good when you play it on your local PC (NOT on Youtube) with videolan or mpc_hc?
    Is it only blurred on Youtube?
    That's because of YT reencodes all uploaded files. If you are a small youtuber you have to play some tricks to get a better video quality.
    One is to provide a higher video size to get more bandwidth.
  • I actually tried it twice, first time using default settings it shows blurry even locally. Second time I set a bunch of things to higher quality, set 12 instead of 23(default) for cq value(? I think this is how you call it?)...I get a 7G file and couldn't upload to Youtube,
    Eventually I had to set it back to normal H.264 without boosting NVDIA GPU, but it took over 3 times of the time...
    If I want to get a video similar to the normal mode, how should I set the settings?
