Configuration Not Created
  • Hi there,
    Voukoder has been a huge help for me. I used it 4-5 times with no issue. But somehow it's not showing the configuration anymore... When I try to export it says no configuration was selected, but when I click "Configure" again, it tried to open up Voukoder twice, causing Premiere to crash.
    The only difference I could think of as for this time...is that I used proxy (I'm still very very new at video editing). Other than that I can't think of any.
    I pasted the entire log file at the bottom....Hope it helps
    Thank you in advance:)
    Der Inhalt kann nicht angezeigt werden, da er nicht mehr verfügbar ist.
    Log File.txt
  • Vouk 28. März 2020 um 18:20
  • Thank you so much for the reply!
    I tried uninstalling both the connector and voukoder. I can only find 1.2.1 version of the connector, so I have that.
    It's still doing the same thing. I also noticed my Premiere recently started acting a little laggy. When I'm editing the video, there is always a lag when I click the timeline and the blue time moves to where I clicked. The blue line would freeze, not jumping to the position I clicked unless I start playing the video. Same problem is happening with me cutting, deleting clips, The updated change doesn't get refreshed until I play the video...Not sure if these are related at all...
    I even reinstalled premiere for the problem above...I don't know what's happening
    It would be a big help if you could help me get this back and running. I have a GTX 1060, only found out when I'm searching solution for my problem this time that there is a rendering option specially for NVIDIA graphic cards....Want to find more potentials
  • Hi sorry, I think I found the issue... Last time when I create my proxies, I selected QuickTime, but I kept H.264 at configuration.
    I created proxies with H.264 today and it can configure normally now. Thank you again for the useful tool!!
  • Vouk 30. März 2020 um 08:01
    Hat das Label von In Bearbeitung auf Kein Bug geändert.
