voukoder not found gpu amd on my laptop. it always run with cpu + intel hd graphics. someone help me plz? lastest driver for all
voukoder not running on laptop with intel hd graphic + gpu amd
Maybe you can try upgrading to the latest voukoder version first?
voukoder 4.1+connector premiere 1.2.4 but nothing change
i hope voukoder can change gpu manually in amd radeon software or nvidia control panel
thi.vfu
4. April 2020 um 14:46 Hat das Label von 2.0.7 auf 4 geändert. -
thi.vfu
4. April 2020 um 14:46 Hat den Titel des Themas von „voukoder 2.0.7 not running on laptop“ zu „voukoder not running on laptop with intel hd graphic + gpu amd“ geändert. -
Can you please send a new logfile with low level debugging in the settings enabled.
But I guess this is some driver issue. Are both "h264" and "hevc" not available?
8. April 2020 um 11:46 Hat das Label In Bearbeitung hinzugefügt. -
Hello, I have a similar problem, I have a laptop with the standard Intel GPU and an AMD GPU and the AMD GPU related option does not appear
My AMD drivers are up to date.
All file you need
Other applications and games still run perfectly with gpu AMD (include PREMIERE CC 2018 + Setting: Opencl Render+Hardware encoding/Software encoding)
Lastest driver from homepage amd.com
Ich glaube die HD8000M kann kein AMF encoding
For the english users: It seems the HD8000M series does not support GPU video encoding.
really? i didn't find any infomation about it
As in the AMD table there are "Yes", "No" and blank values provided in "xyz Encoder" column, I believe blank value means "no information available".
so sad
20. April 2020 um 16:36 Hat das Label von In Bearbeitung auf Kein Bug geändert. -
20. April 2020 um 16:36 Hat das Label 4 entfernt. -
22. Februar 2022 um 21:12 Hat das Thema aus dem Forum Bug reports nach Closed verschoben.
