    Release Candidate 1
    Fixes
    • Closing the separate logfile properly
    • Fixed atrim selection by sample count
    • Fixed bwdif filter options matching their labels
    • Fixed deinterlacing filters (Bobbing)
    • Fixed audio stream bug
    • Clearing options on encoder change
    Changes
    • (h264_amf, hevc_amf) Added "GOP size" option
    • (x264,x265) Added more options (@Kleinrotti )
    • Added wavpack encoder (@Kleinrotti)
    • Added SVT-AV1 encoder (experimental)
    Notes
    This is not the final version 5 release. Use it on your own risk.
    For using NVENC encoders driver version 436.15 or newer is required.
    Download
    https://github.com/Vouk/voukoder/releases/tag/5rc1
    Release Candidate 2
    Fixes
    Changes
    • (x264,x265) fixed loading of grouped parameters
    • Added iAvoe's x264 presets
    Notes
    Download
    https://github.com/Vouk/voukoder/releases/tag/5rc2
    Release Notes
    If you like Voukoder and especially if it helps saving time and money in your business - please consider supporting the project by paypal or on patreon. Thank you.
    I am also looking for sponsors and partners. Please contact me if you are interested.
    Important
    Make sure you are using the latest connector for your application(s)!
    Fixes
    Changes
    • Added iAvoe 's x264 presets
    Notes
    Credits
    Thanks to my all supporters - especially the platinum tier patrons ValnirÆsirsson and Gronkh!
