I have a problem with the encoding of AV1 on media encoder. I do things normally, I encode in professional mode for quality, in variable (since in constant quality does not work with encoding, its puts me a yellow cross) its works in variable, but during encoding , nothing happens, its launched, but nothing ... I don't understand.
AV1 codec problem media encoder
Thomas78 -
19. April 2020 um 21:37
https://zupimages.net/viewer.php?id=20/16/eqty.png (voici la capture)
Can you append to logfile of voukoder?
[21:33:57] Filename: D:\test.mp4
[21:33:57] Application: Voukoder (Adobe Premiere)
[21:33:57] - Video -------------------------------------
[21:33:57] Frame size: 3840x3100
[21:33:57] Pixel aspect: 1:1
[21:33:57] Timebase: 1001/24000 (23.98 fps)
[21:33:57] Interlaced: No
[21:33:57] Encoder: libsvt_av1
[21:33:57] Options: _pixelFormat=yuv420p b=7000000 maxrate=7000000 preset=3 profile=professional rc=vbr tier=main
[21:33:57] Side data: <none>
[21:33:57] Filters: <none>
[21:33:57] Passes: 1
[21:33:57] Color range: unknown
[21:33:57] Color space: unknown
[21:33:57] Color primaries: unknown
[21:33:57] Color transfer: unknown
[21:33:57] - Audio -------------------------------------
[21:33:57] Timebase: 1/48000
[21:33:57] Channels: 2
[21:33:57] Encoder: aac
[21:33:57] Options: _sampleFormat=fltp b=96000 profile=aac_low
[21:33:57] ---------------------------------------------
[21:33:57] Opening codec: libsvt_av1 with options: b=7000000|maxrate=7000000|preset=3|profile=professional|rc=vbr|tier=main
You could try to set another profile or unset the maxrate value. Or the frame size of 3840x3100 is the problem. Some options do not work reliable until now.
Okay i will try and i will tell you, thanks
I remade in 1920x1080 format, normal size, its does the same thing, its load, but nothing happens. His leash as on my capture, his load but his does nothing. I don't understand where it can come from? For me it doesn't work
please help, thank you
Does the default settings with Av1 work?
No, it does the same thing, its load, but nothing happens when encoding.
Kleinrotti AV1 is just extremely slow and needs a high performance processor. Otherwise it might seem as "not working".
i compared youtube's videos (av1 & h.264) & the h.264 version of the calling - wherever you wil go was so much better than av1 version.
the blur of av1 is very high!!!
