[Premiere / AME] Is there a consensus on...
  • The best Voukoder 5 settings for Youtube quality when exporting in 1440 or 2160p? Something that can make the best of the compression that the file will have to endure?
    I'm having weird audio compression problems lately, but I'd like to know if there's been any discussion over this matter.
    Are there settings that I can use that will be better than "leaving it at that"? :saint:
  • Following this topic...follow up question: I'm uploading my videos to a Chinese video site, Bilibili. They have a 7G limit for file size...I've only been increasing the quantitizer so files can be smaller. Is there a setting, while maintaining decent quality, that will help make the file size smaller?
    Youtube will re-encode anything you upload so it's best to keep your original video at highest quality possible; so go with a low CRF say ~12 and keep audio lossless.
    Take a look at iAvoe's post and scroll down to x265 Slow Hard
    Use Preset: Medium, slow is 3x slower than medium and medium is already very slow to encode
    I'll change Sample Adaptive Offset to No though, I'm not a fan of it's smoothing effect.
    Base CRF off length and frame rate of your video
    Using CRF24 should be enough for 2h movie and stay under 7GB
    Audio: Vorbis
    Strategy: VBR
    Bitrate: Not sure if your doing Stereo or surround, See Opus Recommended Settings for appropriate bitrate
