Adobe Media Encoder | Voukoder not Installing
  • Adobe After Effects 2020
    Adobe Media Encoder 2020
    It seems that Voukoder for Media Encoder is not installing correctly or something, Voukoder works for Sony Vegas and After Effects but the option for Voukoder in Media Encoder is not popping up??
    Is there anything im doing wrong to install it, if so help me!!
    I have installed the Core Voukoder and I have installed Voukoder for After Effects and Premiere Pro.
    I was guessing that installing it for Premiere Pro would be the same for Media Encoder because there isnt an option and Premiere Pro has the IDENTICAL export options as Media Encoder.
    If someone can help me that would be greatly appreciated !!!!!!
    Did you install your Adobe Apps to c:\Program Files\Adobe\... ?
    Please Check if there is a Voukoder.prm in C:\Program Files\Adobe\Common\Plug-ins\7.0\MediaCore
