24. Juni 2020 um 15:23 #1 When I render out the Adobe After EffectsThe GPU usage is very lowIt is only 1%!Is this normal?I thought using NVIDIA NVENC will use up more GPU to render it faster?
24. Juni 2020 um 22:01 Offizieller Beitrag #2 Didn't you ask the same question here already? Adobe After Effects encoding not using dedicated GPU
