    Release Candidate 1
    RELEASE CANDIDATE - NOT READY FOR PRODUCTION
    If you like Voukoder and especially if it helps saving time and money in your business - please consider supporting the project by paypal or on patreon. Thank you.
    I am also looking for sponsors and partners. I am doing custom encoder solutions as well. Please contact me if you are interested.
    Important
    Make sure you are using the latest connector for your application(s)!
    Fixes
    • Updated the x264 presets (Thanks to iAvoe)
    • Fixed HAP encoder pixel format
    • Fixed NVENC encoders "Good quality" preset ("preset" option)
    • Increased AAC offset by 1024 samples (fixes audio delay)
    Changes
    • Added QuickTime RLE encoder
    Notes
    For using NVENC (SDK 10) encoders driver version 450.51 or newer is required.
    Download
    https://github.com/Vouk/voukoder/releases/tag/6rc1
    Release Notes
    Important
    Fixes
    Changes
    • Build with latest stable FFmpeg 4.3.1
    Notes
    Credits
    Thanks to my all supporters - especially the platinum tier patrons ValnirÆsirsson and Gronkh!
    Version 6.1 - Release Candidate 3
    Important
    Fixes
    • Using proper release version of FFmpeg 4.3
    • NVENC encoders appear for older (Kepler) GPUs again
    • Fixed NVENC default options
    Notes
    For using NVENC (SDK 10) encoders driver version 445.87 or newer is required.
    Credits
    Thanks to my all supporters - especially the platinum tier patron Gronkh!
    Version 6.1
    Important
    Fixes
    Changes
    • Updated to wxWidgets 3.1.4
    Notes
    Credits
    Download
    https://github.com/Vouk/voukoder/…oukoder-6.1.msi
    Version 6.2
    Important
    Make sure you are using the latest connector for your application(s).
    Fixes
    • Fixed the encoder list being empty for some users
    Changes
    • Build with NVIDIA SDK 9.0 to support older mobile GPUs again
    Notes
    For using NVENC (SDK 9.0) encoders driver version 418.8 or newer is required.
    Credits
    Download
    https://github.com/Vouk/voukoder/…oukoder-6.2.msi
