Hardware encoders not even using gpu.
  • What I mean in the title is that the hardware encoders are (reported by taskmanager) using video decode... but why? Used to work.
    I don't know why it all of a sudden stopped working
    Edit: using either x265 or HEVC give the same result, no CPU usage and no video encode on the GPU, only video decode
    Einmal editiert, zuletzt von Melting Ice (24. August 2020 um 01:58)
    Video Decode is necessary because your source clips are most likely compressed (=encoded). The NLE needs to uncompress it first, then does its thing with effects, cuts, and color corrections and sends it back to voukoder.
    Depending on the source format and frame size this can take a while so encoding might get really slow.
    Details on this: Voukoder Performance Analysis
  • Vouk 26. August 2020 um 14:00
