hi i just get my new laptop with gtx1660Ti since my 1070 die in september....
so i load all my settings and presets and get problems on new system...
render 4k into in any preset mp4 cuda or prores or any..just take from video i think middle area in 1080p
cut anything else and export in 1080p only this area...
if i put in "filters" tab scale filter and set it in 1080p will video exports full size..but ofc in 1080p...
UPD: if i put 4k prores file or any h264, in encoder with same presets it works good...but any bt2020 become croped
but there is one more problem - it ignore color managment
i work with bt2020 and in premiere i use colormanagment and get normal colors.
but when i render it become like original w/o transforms...
if i try use colorspace filter in filters tab, so any settings i combine, it get me crazy result..i think main reason - thereis no HLG in transfer gamma..
also i just do little google, is it nessesary for voucoder to install 3GB cuda toolkit?
i never install it before an was no problem but now idk..
driver for studio 460.89, vouk7.1, prem14.7
