Unable to initialize the encoder for Voukoder 7.1
  • I'm using Voukoder 7.1current latest version. I tried to render 2K 30 FPS with Voukoder h.264 default settings and I got error. Below is log file massage.
    [22:45:47] =============================================
    [22:45:47] Voukoder 7 (7.0.115)
    [22:45:47] by Daniel Stankewitz
    [22:45:47] ---------------------------------------------
    [22:45:47] AMD Athlon(tm) II X4 640 Processor
    [22:45:47] 4 logical cores
    [22:45:47] 8189 MB system memory
    [22:45:47] Display #0 on: NVIDIA GeForce GTS 450
    [22:45:47] Export started
    [22:45:47] Filename: H:\dv\test.mp4
    [22:45:47] Application: Voukoder (Adobe Premiere)
    [22:45:47] - Video -------------------------------------
    [22:45:47] Frame size: 1920x1080
    [22:45:47] Pixel aspect: 1:1
    [22:45:47] Timebase: -2136068775/-920509440 (0.43 fps)
    [22:45:47] Interlaced: No
    [22:45:47] Encoder: libx264
    [22:45:47] Options: _pixelFormat=yuv420p crf=17.000 opencl=1 preset=medium rc=crf
    [22:45:47] Side data: <none>
    [22:45:47] Filters: <none>
    [22:45:47] Passes: 1
    [22:45:47] Color range: unknown
    [22:45:47] Color space: unknown
    [22:45:47] Color primaries: unknown
    [22:45:47] Color transfer: unknown
    [22:45:47] - Audio -------------------------------------
    [22:45:47] Timebase: 1/48000
    [22:45:47] Channels: 2
    [22:45:47] Encoder: aac
    [22:45:47] Options: _sampleFormat=fltp b=320000 profile=aac_low
    [22:45:47] Opening codec: libx264 with options: crf=17.000|opencl=1|preset=medium|rc=crf
    [22:45:47] FFmpeg: The encoder timebase is not set.
    [22:45:47] Failed opening codec: libx264
    [22:45:47] Unable to open video encoder: libx264
    [22:45:47] Closing encoders ...
    [22:45:47] Opening encoder failed! Aborting ...
    Einmal editiert, zuletzt von kevin ke (25. Januar 2021 um 16:13)
  • Vouk 11. Februar 2021 um 10:46
