Opening encoder failed! Aborting
  • Hello!
    I cannot make the encoder working, when trying to use the nvenc coder, I got an error message.
    Regards,
    Krzysiek
    [00:15:44] =============================================
    [00:15:44] Voukoder 7.2 (7.2.121)
    [00:15:44] by Daniel Stankewitz
    [00:15:44] ---------------------------------------------
    [00:15:44] AMD Ryzen Threadripper 3970X 32-Core Processor
    [00:15:44] 64 logical cores
    [00:15:44] 130965 MB system memory
    [00:15:44] Display #0 on: NVIDIA GeForce RTX 3080
    [00:15:44] Export started
    [00:15:44] Filename: C:\Projekty\wersja_pl\Filmy_renderowane\calosc_filmu.mp4
    [00:15:44] Application: Voukoder (Adobe Premiere)
    [00:15:44] - Video -------------------------------------
    [00:15:44] Frame size: 960x720
    [00:15:44] Pixel aspect: 4:3
    [00:15:44] Timebase: 1/25 (25.00 fps)
    [00:15:44] Interlaced: Top first
    [00:15:44] Encoder: h264_nvenc
    [00:15:44] Options: _computeCapability=8.6 _pixelFormat=yuv420p gpu=0 preset=medium profile=high qp=15 rc=constqp
    [00:15:44] Side data: <none>
    [00:15:44] Filters: <none>
    [00:15:44] Passes: 1
    [00:15:44] Color range: unknown
    [00:15:44] Color space: unknown
    [00:15:44] Color primaries: unknown
    [00:15:44] Color transfer: unknown
    [00:15:44] - Audio -------------------------------------
    [00:15:44] Timebase: 1/48000
    [00:15:44] Channels: 2
    [00:15:44] Encoder: aac
    [00:15:44] Options: _sampleFormat=fltp b=320000 profile=aac_low
    [00:15:44] Opening codec: h264_nvenc with options: gpu=0|preset=medium|profile=high|qp=15|rc=constqp
    [00:15:45] Failed opening codec: h264_nvenc
    [00:15:45] Unable to open video encoder: h264_nvenc
    [00:15:45] Closing encoders ...
    [00:15:45] Opening encoder failed! Aborting ...
  • Vouk 10. März 2021 um 06:25
