Released Voukoder 0.8.1
    Welcome to a new Voukoder release! Lots of stuff has happened since the last time.
    IMPORTANT: YOU MIGHT HAVE TO FLUSH YOUR PARAMETER CACHE AFTER UPDATING! SEE:
    => Installation, Updates and Deinstallation <=
    Changes:
    • Added 2pass encoding to x264 encoder.
    • Added filesize estimation where possible i.e. for encoders using CBR, ABR or VBR (does not work for CQP or CRF)
    • Voukoder checks for updates on startup and informs the user if an update is available.
    • Added the full bunch of the advanced x265 parameters.
    • Fixed bug in the NVENC encoder parameters (aq-strength).
    • Added libfdk_aac (You need to have "libfdk-aac-1.dll" in either either your c:\windows\system32 directory or in your main Premiere or Media Encoder directory).
    Thanks for your support and please consider donating.
    Edit:
    You can download the libfdk-aac-1.dll i.e. from Sherpyas mplayer page ( http://oss.netfarm.it/mplayer/files/…86_64-v0.1.6.7z ) or build your own one.
