More Muxing choices to add (especially TS)
    I am long time keep looking a way to have the option for muxing to TS (Transport Stream) with H264 and there are just no options.
    Knowing ffmpeg does it. Possible to add TS muxing as an option?
    For streaming is mostly the only option in all the equipment that I used in every Broadcasting room.
    If can be integrated directly into Adobe Media encoder can avoid of switching to another software just to mux to TS and losing time.
    Thank you for the support,
  • Vouk 24. April 2021 um 22:03
    I guess you are talking about "mpegts", right?
    Muxer mpegts [MPEG-TS (MPEG-2 Transport Stream)]:
    Common extensions: ts,m2t,m2ts,mts.
    Mime type: video/MP2T.
    Default video codec: mpeg2video.
    Default audio codec: mp2.
    But it seems it is more about mpeg2.
