no quicktime options
  • Just found this item. Installed with the Resolve connector.
    When I go to configure inside Resolve, i only have the option of MKV and AVI...no quicktime container.
    Quicktime is installed on my system.
    Any advice?
  • Vouk 11. Mai 2021 um 23:59
    Mov is only available if the codec combination of audio and video is supported by the quicktime format. So if you select "ProRes" and "ALAC" MOV should be available.
  • Vouk 13. Mai 2021 um 07:29
    Hat das Label DaVinci Resolve entfernt.
