Hello,
I am using Davinci Resolve Studio 17, version 17.2 Build 11.
From the Readme.txt file, from the Connector plugin, resolve-connector-0.5.0.zip :
1. Extract the contents of this zip file to %ProgramData%\Blackmagic Design\DaVinci Resolve\Support\IOPlugins
2. If the IOPlugins directory does not exist, create it
Support folder does not exist, neither IOPlugins folder.
I have created both of them and copy the contents of the zip file to IOPlugins folder (e.g voukoder_plugin.dvcp.bundle folder and Readme.txt file)
I have then installed voukoder-8.msi
From the C:\Program Files\Voukoder folder, there are the following files
voukoder.dll
voukoder.tlb
I closed and restarted many time Davinci Resolve.
The option for the voukoder in Deliver/Video/Format does not appear.
Have I missed something ?
Thanks in advance,
Mersing.
