PIxelated output when Vegas Pro 18 transitions between events - but not at every transition
  • I have been getting a strange error in MP4s rendered with Voukoder. (Before I go any further, I LOVE Voukoder, beautiful images, small files.)
    The symptom is a brief pixelated image in the rendered file at the point the timeline transitions from one event to the next one. But it only happens about one time in 10 or 15. In one file, the pixelated frames are from a different part of the timeline. . In one file, this happened at the third transition. In another, at the 12th transition. This error does not occur with Magix MP4 template at the same transition.
    The events are Canon MXF files from a Canon XF300, 1920 x 1080, 60p, at 50Mbps. There can be 20 events on a timeline. The events are all butted up against each other, there are no gaps.
    There is the video track, and above it 3 other tracks, one with a simple legacy text that says "7 PM" with clear background, one with a single empty event with a timecode running, and one with song titles and performers' names in a Vegas Credit Roll.
    VEGAS White balance FX is applied to all events.
    Vegas version 18, build 527. Computer AMD Ryzen 3900X 12-core processor at 4GHz not overclocked. 8 GB memory. Source files are on an SSD. Vegas program is on a different SSD. Render output goes on an internal HDD. Running this template with these files, CPU load is over 90% and sometimes hits 100%. NVIDIA GPU is loafing. Windows 10 Pro, OS build 19041.985.
    Voukoder version 7, template: "Video: project default, Audio: project default"
    "Audio: 0 Hz, 0 Channel
    Video: Project Frame Rate, Project Frame Size
    Pixel Aspect Ratio: 1.000"
    (Note: there is audio in the source and the rendered output, and it is working properly.)
    General
    Complete name : L:\Coppelia2021\CopelliaSat7pm\AA1516\AA151602.MXF
    Format : MXF
    Commercial name : XDCAM HD422
    Format version : 1.2
    Format profile : OP-1a
    Format settings : Closed / Complete
    File size : 1.91 GiB
    Duration : 5 min 13 s
    Overall bit rate : 52.2 Mb/s
    Encoded date : 2021-06-05 20:09:55.000
    Writing application : CANON XF300 1.00
    Video
    Format : MPEG Video
    Format version : Version 2
    Format profile : 4:2:2@High
    Format settings : CustomMatrix / BVOP
    Format settings, BVOP : Yes
    Format settings, Matrix : Custom
    Format settings, GOP : M=3, N=15
    Format settings, wrapping mode : Frame
    Codec ID : 0D01030102046001-0401020201040300
    Bit rate mode : Constant
    Bit rate : 50.0 Mb/s
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate : 29.970 (30000/1001) FPS
    Standard : Component
    Color space : YUV
    Chroma subsampling : 4:2:2
    Bit depth : 8 bits
    Scan type : Progressive
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.805
    Stream size : 1.83 GiB (96%)
    Color range : Limited
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    Audio #1
    Format : PCM
    Format settings : Little
    Format settings, wrapping mode : Frame (AES)
    Codec ID : 0D01030102060300
    Bit rate : 768 kb/s
    Channel(s) : 1 channel
    Sampling rate : 48.0 kHz
    Frame rate : 29.970 FPS (1601.6 SPF)
    Bit depth : 16 bits
    Stream size : 28.7 MiB (1%)
    Locked : Yes
    Audio #2
    Format : PCM
    Bit rate : 768 kb/s
    Bit depth : 16 bits
    Locked : Yes
    Other #1
    Type : Time code
    Format : MXF TC
    Time code of first frame : 09:31:09;18
    Time code settings : Material Package
    Time code, striped : Yes
    Other #2
    Type : Time code
    Format : MXF TC
    Time code settings : Source Package
    Other #3
    Type : Time code
    Format : SMPTE TC
    Muxing mode : SDTI
  • Vouk 10. Juni 2021 um 21:25
  • It appears this is not a Voukoder problem. Over on the Vegas Pro forum a user with a similar camera and similar problem suggested I combine all the mxf files into one with a couple simple scripts. He thinks the issue is a buffer in Vegas Pro.
    Another user suggested upping the bitrate.
    Both solutions appear to work.
    I consider this bug closed.
    Thank you
  • Vouk 23. Februar 2022 um 07:20
