Hi, I can't export h264(nvenc) 10b, h265 works, but when I export h264 10b I get this error.
I'm using a Rtx 3070, Premiere 2021(15.1.0), voukoder 9.2.
The only odd thing is that voukoder is using pixelFormat=p010le, when it should use pixelFormat=yuv444p or yuv420p
Thanks in advance.
[00:58:47] =============================================
[00:58:47] Voukoder 9.2 (9.2.137)
[00:58:47] by Daniel Stankewitz
[00:58:47] ---------------------------------------------
[00:58:47] 11th Gen Intel(R) Core(TM) i5-11400 @ 2.60GHz
[00:58:47] 12 logical cores
[00:58:47] 32623 MB system memory
[00:58:47] Display #0 on: NVIDIA GeForce RTX 3070
[00:58:47] Loading: translations/english.json
[00:58:47] Loading: translations/german.json
[00:58:47] Loading: translations/french.json
[00:58:47] Loading: translations/ç®€ä½“ä¸æ–‡.json
[00:58:47] Loading: translations/russian.json
[00:58:47] Loading: encoders/dca.json
[00:58:47] Loading: encoders/eac3.json
[00:58:47] Loading: encoders/truehd.json
[00:58:47] Loading: encoders/wavpack.json
[00:58:47] Loading: encoders/aac.json
[00:58:47] Loading: encoders/ac3.json
[00:58:47] Loading: encoders/alac.json
[00:58:47] Loading: encoders/ffv1.json
[00:58:47] Loading: encoders/flac.json
[00:58:47] Loading: encoders/h264_amf.json
[00:58:47] - Encoder initialization failed (Code: -1313558101)
[00:58:47] Unloading: encoders/h264_amf.json
[00:58:47] Loading: encoders/h264_nvenc.json
[00:58:47] Loading: encoders/hevc_amf.json
[00:58:47] Unloading: encoders/hevc_amf.json
[00:58:47] Loading: encoders/hevc_nvenc.json
[00:58:47] Loading: encoders/libfdk_aac.json
[00:58:47] - Encoder initialization failed (Code: -1)
[00:58:47] Unloading: encoders/libfdk_aac.json
[00:58:47] Loading: encoders/libmp3lame.json
[00:58:48] Loading: encoders/libopus.json
[00:58:48] Loading: encoders/libvorbis.json
[00:58:48] Loading: encoders/libvpx.json
[00:58:48] Loading: encoders/libvpx-vp9.json
[00:58:48] Loading: encoders/libx264.json
[00:58:48] Loading: encoders/libx265.json
[00:58:48] Loading: encoders/pcm_s16le.json
[00:58:48] Loading: encoders/pcm_s24le.json
[00:58:48] Loading: encoders/pcm_s32le.json
[00:58:48] Loading: encoders/prores_ks.json
[00:58:48] Loading: encoders/hap.json
[00:58:48] Loading: encoders/h264_qsv.json
[00:58:48] - Encoder initialization failed (Code: -40)
[00:58:48] Unloading: encoders/h264_qsv.json
[00:58:48] Loading: encoders/hevc_qsv.json
[00:58:48] Unloading: encoders/hevc_qsv.json
[00:58:48] Loading: encoders/libsvtav1.json
[00:58:48] Loading: encoders/vp9_qsv.json
[00:58:48] Unloading: encoders/vp9_qsv.json
[00:58:48] Loading: encoders/gif.json
[00:58:48] Loading: encoders/bmp.json
[00:58:48] Loading: encoders/png.json
[00:58:48] Unloading: encoders/png.json
[00:58:48] Loading: encoders/tiff.json
[00:58:48] Loading: encoders/qtrle.json
[00:58:48] Loading: encoders/utvideo.json
[00:58:48] Loading: encoders/cfhd.json
[00:58:48] Loading: encoders/prores_aw.json
[00:58:48] Loading: muxers/wv.json
[00:58:48] Loading: muxers/matroska.json
[00:58:48] Loading: muxers/mov.json
[00:58:48] Loading: muxers/mp4.json
[00:58:48] Loading: muxers/webm.json
[00:58:48] Loading: muxers/mp3.json
[00:58:48] Loading: muxers/opus.json
[00:58:48] Loading: muxers/ogg.json
[00:58:48] Loading: muxers/flac.json
[00:58:48] Loading: muxers/adts.json
[00:58:48] Loading: muxers/wav.json
[00:58:48] Loading: muxers/h264.json
[00:58:48] Loading: muxers/hevc.json
[00:58:48] Loading: muxers/mpeg2video.json
[00:58:48] Loading: muxers/mpegts.json
[00:58:48] Loading: muxers/gif.json
[00:58:48] Loading: muxers/image2#bmp.json
[00:58:48] Loading: muxers/image2#png.json
[00:58:48] Loading: muxers/image2#tif.json
[00:58:48] Loading: muxers/avi.json
[00:58:48] Loading: filters/bwdif.json
[00:58:48] Loading: filters/colorspace.json
[00:58:48] Loading: filters/crop.json
[00:58:48] Loading: filters/eq.json
[00:58:48] Loading: filters/hqdn3d.json
[00:58:48] Loading: filters/nlmeans.json
[00:58:48] Loading: filters/pad.json
[00:58:48] Loading: filters/removegrain.json
[00:58:48] Loading: filters/setdar.json
[00:58:48] Loading: filters/setparams.json
[00:58:48] Loading: filters/setsar.json
[00:58:48] Loading: filters/tmix.json
[00:58:48] Loading: filters/unsharp.json
[00:58:48] Loading: filters/yadif.json
[00:58:48] Loading: filters/zscale.json
[00:58:48] Loading: filters/atrim.json
[01:13:00] ---------------------------------------------
[01:13:00] Export started
[01:13:00] Filename: D:\Videos\Inazuma Ed 1-1_4.mp4
[01:13:00] Application: Voukoder (Adobe Premiere)
[01:13:00] - Video -------------------------------------
[01:13:00] Frame size: 1280x720
[01:13:00] Pixel aspect: 1:1
[01:13:00] Timebase: 1001/30000 (29.97 fps)
[01:13:00] Interlaced: No
[01:13:00] Encoder: h264_nvenc
[01:13:00] Options: _computeCapability=8.6 _pixelFormat=p010le gpu=0 preset=medium profile=main qp=23 rc=constqp
[01:13:00] Side data: <none>
[01:13:00] Filters: <none>
[01:13:00] Passes: 1
[01:13:00] Color range: unknown
[01:13:00] Color space: unknown
[01:13:00] Color primaries: unknown
[01:13:00] Color transfer: unknown
[01:13:00] - Audio -------------------------------------
[01:13:00] Timebase: 1/48000
[01:13:00] Channels: 2
[01:13:00] Encoder: aac
[01:13:00] Options: _sampleFormat=fltp b=320000 profile=aac_low
[01:13:00] Opening codec: h264_nvenc with options: gpu=0|preset=medium|profile=main|qp=23|rc=constqp
[01:13:00] Failed opening codec: h264_nvenc
[01:13:00] Unable to open video encoder: h264_nvenc
[01:13:00] Closing encoders ...
[01:13:00] Opening encoder failed! Aborting ...
