If I change it to anything else voukoder renders it fine. Is this a bug or I'm missing something?
23,97 sequence always hangs Premiere at rendering
6. August 2021 um 19:12 Hat das Thema freigeschaltet. -
Hello?
Please post a logfile with "low level debug" enabled. (See sticky thread)
[01:10:48] Export started
[01:10:48] ---------------------------------------------
[01:10:48] Filename: A:\YT\Voukoder 23 976 test.mp4
[01:10:48] Application: Voukoder (Adobe Premiere)
[01:10:48] - Video -------------------------------------
[01:10:48] Frame size: 1920x1080
[01:10:48] Pixel aspect: 1:1
[01:10:48] Timebase: 1001/24000 (23.98 fps)
[01:10:48] Interlaced: No
[01:10:48] Encoder: libx264
[01:10:48] Options: _pixelFormat=yuv420p crf=18.000 opencl=1 preset=medium profile=high rc=crf
[01:10:48] Side data: <none>
[01:10:48] Filters: <none>
[01:10:48] Passes: 1
[01:10:48] Color range: unknown
[01:10:48] Color space: unknown
[01:10:48] Color primaries: unknown
[01:10:48] Color transfer: unknown
[01:10:48] - Audio -------------------------------------
[01:10:48] Timebase: 1/48000
[01:10:48] Channels: 2
[01:10:48] Encoder: aac
[01:10:48] Options: _sampleFormat=fltp b=320000 profile=aac_low
[01:10:48] Opening codec: libx264 with options: crf=18.000|opencl=1|preset=medium|profile=high|rc=crf
[01:10:48] FFmpeg: using mv_range_thread = 88
[01:10:48] FFmpeg: using SAR=1/1
[01:10:48] FFmpeg: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX FMA3 BMI2 AVX2
[01:10:48] FFmpeg: profile High, level 4.0, 4:2:0, 8-bit
[01:10:48] FFmpeg: 264 - core 164 r3065 ae03d92 - H.264/MPEG-4 AVC codec - Copyleft 2003-2021 - http://www.videolan.org/x264.html - options: cabac=1 ref=3 deblock=1:0:0 analyse=0x3:0x113 me=hex subme=7 psy=1 psy_rd=1.00:0.00 mixed_ref=1 me_range=16 chroma_me=1 trellis=1 8x8dct=1 cqm=0 deadzone=21,11 fast_pskip=1 chroma_qp_offset=-2 threads=6 lookahead_threads=1 sliced_threads=0 nr=0 decimate=1 interlaced=0 bluray_compat=0 constrained_intra=0 bframes=3 b_pyramid=2 b_adapt=1 b_bias=0 direct=1 weightb=1 open_gop=0 weightp=2 keyint=250 keyint_min=23 scenecut=40 intra_refresh=0 rc_lookahead=40 rc=crf mbtree=1 crf=18.0 qcomp=0.60 qpmin=0 qpmax=69 qpstep=4 ip_ratio=1.40 aq=1:1.00
[01:10:48] Opening codec: aac with options: b=320000|profile=aac_low
[01:10:48] FFmpeg: Setting default whitelist 'file,crypto,data'
[01:10:48] FFmpeg: Output #0, mp4, to 'A:\YT\Voukoder 23 976 test.mp4':
[01:10:48] FFmpeg: Metadata:
[01:10:48] FFmpeg: encoding_tool :
[01:10:48] FFmpeg: Voukoder (Adobe Premiere)
[01:10:48] FFmpeg:
[01:10:48] FFmpeg: Stream #0:0
[01:10:48] FFmpeg: , 0, 1001/24000
[01:10:48] FFmpeg: : Video: h264 (libx264), 1 reference frame, yuv420p(progressive), 1920x1080 (0x0) [SAR 1:1 DAR 16:9], 0/1, q=-1--1
[01:10:48] FFmpeg: 23.98 fps,
[01:10:48] FFmpeg: 23.98 tbn
[01:10:48] FFmpeg:
[01:10:48] FFmpeg: Stream #0:1
[01:10:48] FFmpeg: , 0, 1/48000
[01:10:48] FFmpeg: : Audio: aac (LC), 48000 Hz, stereo, fltp, delay 1024, 320 kb/s
[01:10:48] FFmpeg:
[01:10:48] Requesting pixel format: yuv420p
[01:10:48] FFmpeg: tb:1/48000 samplefmt:fltp samplerate:48000 chlayout:stereo
[01:10:48] FFmpeg: Setting 'n' to value '1024'
[01:10:48] FFmpeg: Setting 'p' to value '0'
[01:10:48] FFmpeg: query_formats: 3 queried, 6 merged, 0 already done, 0 delayed
[01:10:48] Applying audio filters: asetnsamples=n=1024:p=0
[01:10:48] Frame #0: vRender: 18033 us, vProcess: 4 us, vEncoding: 3283 us, aRender: 47 us, aEncoding: 5901 us, Latency: 28450 us
[01:10:48] Frame #1: vRender: 35295 us, vProcess: 7 us, vEncoding: 3576 us, aRender: 78 us, aEncoding: 1249 us, Latency: 40247 us
[01:10:48] Frame #2: vRender: 156 us, vProcess: 5 us, vEncoding: 5180 us, aRender: 112 us, aEncoding: 985 us, Latency: 6490 us
[01:10:48] Frame #3: vRender: 3703 us, vProcess: 7 us, vEncoding: 12181 us, aRender: 76 us, aEncoding: 1808 us, Latency: 17804 us
[01:10:48] Frame #4: vRender: 32 us, vProcess: 18 us, vEncoding: 7711 us, aRender: 77 us, aEncoding: 2118 us, Latency: 9990 us
[01:10:48] Frame #5: vRender: 51 us, vProcess: 4 us, vEncoding: 5528 us, aRender: 78 us, aEncoding: 926 us, Latency: 6612 us
[01:10:48] Frame #6: vRender: 18 us, vProcess: 4 us, vEncoding: 6068 us, aRender: 72 us, aEncoding: 988 us, Latency: 7237 us
[01:10:48] Frame #7: vRender: 17 us, vProcess: 3 us, vEncoding: 3264 us, aRender: 78 us, aEncoding: 911 us, Latency: 4294 us
[01:10:48] Frame #8: vRender: 21 us, vProcess: 4 us, vEncoding: 3334 us, aRender: 75 us, aEncoding: 948 us, Latency: 4408 us
[01:10:48] Frame #9: vRender: 203 us, vProcess: 4 us, vEncoding: 4287 us, aRender: 328 us, aEncoding: 1990 us, Latency: 6845 us
[01:10:48] Frame #10: vRender: 50415 us, vProcess: 5 us, vEncoding: 3148 us, aRender: 105 us, aEncoding: 1002 us, Latency: 54709 us
[01:10:48] Frame #11: vRender: 2301 us, vProcess: 4 us, vEncoding: 3176 us, aRender: 90 us, aEncoding: 926 us, Latency: 6521 us
[01:10:48] Exported 12 frames in 0 seconds. (avg. 61.22 fps)
[01:10:48] =============================================
[01:10:48] Voukoder 9.3 (9.3.138)
[01:10:48] by Daniel Stankewitz
[01:10:48] Intel(R) Core(TM) i5-6600K CPU @ 3.50GHz
[01:10:48] 4 logical cores
[01:10:48] 16272 MB system memory
[01:10:48] Display #0 on: NVIDIA GeForce GTX 1070
[01:10:48] FFmpeg:
[01:10:48] FFmpeg:
[01:10:48] FFmpeg:
Looks okay, it exported 12 Frames with no errors.
The file is a dud. That's when it crashed Adobe at 99% of renderer
Here Crashed Adobe 40% in
Here Crashed Adobe 40% in Second log
Any news?
I've tried several exports with your settings. ~30min each. No issues so far. I assume you have enough disk space left on that drive?
Yep
If I set any other fps in the sequence there's no issue. It's only for 23,976 for some reason.
It's Premiere Pro 2018 if it matters.
The log does say it the encoding didn't finish right? What's the cause then?
Vouk?
I dunno It keeps happening randomly
Can anybody else reproduce this?
With the installation of version 10 the problem is gone.
14. November 2021 um 08:49 Hat das Label Kein Bug hinzugefügt. -
hahaha not a bug? Vouk I meant Voukoder version 10 not windows 10
I just updated from 9.3 to 10.1 and that did it
16. November 2021 um 09:42 Hat das Label von Kein Bug auf Behoben geändert. -
22. Februar 2022 um 20:36 Hat das Thema aus dem Forum Bug reports nach Closed verschoben.
