Best Lossless Format for Intermediate Files (Vegas Pro 18)
  • Hi There,
    I'm looking at cleaning up some noisy VFR dark video I have for a project, prior to working on my composition. Using Neat DeNoise, standard contrast and sharpening on each individual source file which is VFR from phones. Media info below. But I'm wondering what the best option is for a lossless intermediate format so I don't lose any quality before editing within my larger composition project. I know ProRes is a favorite but rendering is Soooo slow. Wondering if I did a lossless H264 or any other format, it might work just as well and render faster.
    Thanks - I'm new to Voukoder, any recommendations welcome.
    Scott
    General
    Complete name : C:\Users\me\Documents\Video_local\KPLG\RWTC\20210620_144221.mp4
    Format : MPEG-4
    Format profile : Base Media / Version 2
    Codec ID : mp42 (isom/mp42)
    File size : 1.39 GiB
    Duration : 7 min 1 s
    Overall bit rate : 28.2 Mb/s
    Encoded date : UTC 2021-06-20 18:49:24
    Tagged date : UTC 2021-06-20 18:49:24
    com.android.version : 11
    Video
    Format : HEVC
    Format/Info : High Efficiency Video Coding
    Format profile : Main@L5.1@Main
    Codec ID : hvc1
    Codec ID/Info : High Efficiency Video Coding
    Source duration : 7 min 1 s
    Bit rate : 28.0 Mb/s
    Width : 3 840 pixels
    Height : 2 160 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Variable
    Frame rate : 30.000 FPS
    Minimum frame rate : 15.005 FPS
    Maximum frame rate : 42.898 FPS
    Standard : PAL
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.112
    Stream size : 1.37 GiB (99%)
    Source stream size : 1.37 GiB (99%)
    Title : VideoHandle
    Language : English
    Color range : Limited
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    mdhd_Duration : 421651
    Codec configuration box : hvcC
    Audio
    Format : AAC LC
    Format/Info : Advanced Audio Codec Low Complexity
    Codec ID : mp4a-40-2
    Bit rate mode : Constant
    Bit rate : 256 kb/s
    Channel(s) : 2 channels
    Channel layout : L R
    Sampling rate : 48.0 kHz
    Frame rate : 46.875 FPS (1024 SPF)
    Compression mode : Lossy
    Stream size : 12.9 MiB (1%)
    Title : SoundHandle
    Language : English
  • Vouk 11. September 2021 um 13:47
  • Unfortunately hevc lossless does not seem to be implemented in Voukoder even though it is implemented perfectly in ffmpeg with a transcode script such as this:
    ffmpeg -i "INFILE.MOV" -c:v libx265 -x265-params lossless=1 "OUTFILE.MOV"
    x264 cannot actually achieve lossless. It's lossless setting is close but ProRes422 is generally a little better quality, faster rendering, and smaller. MagicYUV is another possible option.
  • If you need a mathematical lossless intermediate codec check out MagicYUV.
    MYUV (MagicYUV) is just a space waster format and you should buy it if you really want to use it. (the dev force you to buy it, because free version is really useless comparing to options that full version offer!)
  • Not many options left, use: MKV (FFV1/FLAC or PCM)
  • I've created a pull request to submit the parameters, it just needs some time to be tested and updated to next/later release. Currently you need to go to Option tab, and find, apply the settings yourself :)
