hello,
i'm a green hand to voukoder and just started to test it with my DVR 17 recently. it's great that i could export my files in proress, but it seems that the exporting time was doubled, as well as the file size, which turned out to be twice, comparing with the original file.
i'm just wondering whether this correct or not, as i've read the knowledge thread, voukoder does won't hasten the exporting time, but it's so wierd that the time was doubled. and it's also wierd that the file size would be doubled under proress.
my cpu: Intel(R) Core(TM) i7-4720HQ CPU @ 2.60GHz 2.60 GHz, is it because my budy is too old fashioned?
https://www.imagebam.com/view/ME3MHUR
above is the codec i've chosen
besides, i've also tested it with h.264
https://www.imagebam.com/view/ME3MHUS
in this situation, file sizes are small, but exporting time were still doubled
then i selected h.264(nvenc), since my graphic card is gtx960m
https://www.imagebam.com/view/ME3MHUT
i first chose yuv4448bit, in this situation, not only exporting time was halvend, but also the file size were pretty small
then i selected 10bit, unluckily, the exporting failed and DVR automatically closed. i think may be this is because gtx960m can't encode 10bit files.
so maybe i should be more patient with file size and exporting time since i want to use proress.
Or, will it be improved in the future?
Best regards,
Sam
