11. Oktober 2021 um 09:51 #1 When I select lossless preset , nothing happens in the converted file and instead of - lossless, all the extra settings are added to the converted file!lossless mode does not work!please do something about it, its completely broken.
PC User 11. Oktober 2021 um 10:05 Hat den Titel des Themas von „Lossless mode of x.265 doesn't work“ zu „Lossless mode of x265 doesn't work“ geändert.
14. Oktober 2021 um 08:20 Offizieller Beitrag #2 It is not completely broken. It was just working in near-lossless mode ( https://x265.readthedocs.io/en/stable/lossless.html ) which is 99,9% lossless.It is fixed in the next version.P.S.: One post would've been enough.
14. Oktober 2021 um 16:01 #3 Zitat von Vouk It is not completely broken. It was just working in near-lossless mode ( https://x265.readthedocs.io/en/stable/lossless.html ) which is 99,9% lossless.It is fixed in the next version.P.S.: One post would've been enough. Thank you.But in the advanced options Voukoder does not show the -- lossless.
