Please add Hybrid codec selection (Adobe's native video codecs + Voukoder's Dolby/DTS), otherwise please add MPEG-2 video with DVD compatible + .VOB container.
Add MPEG-2 encoder (with Dolby/DTS)
Hybrid encoding is not possible with the i.e. Adobe product line.
Is there anybody else still needing an MPEG2 encoder with vob output?
It's like saying: MP3 & JPEG is dead!
It's like asking: Is there any demand for this?
MPEG-2 video encoding is still available in Adobe Media Encoder, but not Dolby/DTS codecs!
I haven't burned a DVD/VOB (with MP2) probably 2 years but when I do, I do Frameserver to a "real Mpeg 2 encoder" instead of that sorry excuse that Adobe provides. Tapping into FFMPEG's mp2 encoder would help a lot ... if I ever do DVDs again.
Which one is better quality?
I've always used TMPGEnc Video Mastering Works and the old Carbon Coder ... but then I fold that output back into the old Adobe Encore for creating the DVD. To use Encore efficiently I have to merge back into the MP2 the Premiere medadata ... using EXIFTool(so I get chapter markers).
I did analysis and every MP2 encoder was better than Premiere in terms of speed and quality.
Added MPEG2 encoder (with VOB, M2V and TS) container
Available in next release.
16. Oktober 2021 um 10:40 Hat das Label von wcf.acp.label.label6 auf Fertig geändert. -
16. Oktober 2021 um 10:40 Hat das Label Adobe Premiere / MediaEncoder entfernt. -
16. Oktober 2021 um 11:07 Hat den Titel des Themas von „Hybrid codec selection (Adobe's native video codec + Voukoder's Dolby/DTS)“ zu „Add MPEG2 encoder (with DTS)“ geändert. -
Thank you, Daniel.
I still use this encoder to produce DVD and BluRay.
The most current versions of Vegas Pro, Premiere and Media Encoder still have the MPEG-2 encoder, but no longer have the Dolby Digital AC3 audio option that is needed to avoid re-recoding in software that are used for DVD and Bluray authoring (DVD Arachitect and Adobe Media Encore). This hampers and delays the process of creating and authoring DVd and BluRay.
This option will be very useful as it will now be possible again to encode MPEG-2 with AC3 audio using Voukoder in the latest versions of Vegas Pro, Premiere and Media Encoder.
Thank you very much for this option!
PC User
17. Oktober 2021 um 07:46 Hat den Titel des Themas von „Add MPEG2 encoder (with DTS)“ zu „Add MPEG2 encoder (with Dolby/DTS)“ geändert. -
Does it support splitting output files to 1GB (output)?
PC User
2. November 2021 um 20:21 Hat den Titel des Themas von „Add MPEG2 encoder (with Dolby/DTS)“ zu „Add MPEG-2 encoder (with Dolby/DTS)“ geändert. -
23. Februar 2022 um 13:11 Hat das Thema aus dem Forum Feature requests nach Closed feature requests verschoben.
