Please support audio-only outputs of encoders & not just video, like: .OPUS, FLAC, .OGG (Vorbis) & LAME MP3.
Audio only output of Voukoder enocders
Did you try to disable the video track? It's been supported for years now.
2. November 2021 um 06:53 Hat das Label von wcf.acp.label.label6 auf Fertig geändert. -
Thanks Daniel, the wizard!
Is the MP3 encoder used in the Voukoder a LAME?
Also, please pin the guide: how to use Voukoder.
Yes, it is LAME.
Yes, it is LAME.
Please add advanced options to LAME like: quality settings, stereo or joint, etc.
29. November 2021 um 18:53 Hat das Label Adobe Premiere / MediaEncoder entfernt. -
23. Februar 2022 um 13:11 Hat das Thema aus dem Forum Feature requests nach Closed feature requests verschoben.
