5120x2160 using 264 Nvidia + Vaukoder
  • Hello.
    First of all, I would like to say "thank you" for making this awesome thing :) It helps me a lot and I decided to send you some bucks for few beers.
    But also I decided to ask about some help.
    I'm using voukoder with typical settings for 3440x1440 resolution (21:9), but when I'm trying to use higher - 5120x2160 (21:9) Adobe says that there's no NVENC session for it.
    Despite only difference is the resolution of rendered project - changed from 3440x1440 to 5120x2160. That's the only thing I changed, it works flawless on 3440x but puts this error on 5120x.
    Adobe says it might be problem with combinations of options, but this is just higher resolution. Any ideas if there's option to render with such resolution, or simply voukoder is limited to 3440x1440 here?
    Some details that may be interesting: 2080ti, 32 GB RAM, Premiere 2022, newest version of drivers and newest Voukoder version.
  • Vouk 20. November 2021 um 07:46
