Run Voukoder on both Vegas 18 and Vegas 19 simultaneously
    I have been using Voukoder for several months for Vegas 18 and works like a champ - really great - thank you. I just updated to the latest version 10.1 and the Vegas connector. The connector installs in:
    C:\Program Files\VEGAS\VEGAS Pro 18.0
    and then works just fine.
    I then downloaded a trial version of Vegas 19, but alas Voukoder does not show up. If I uninstall the connector and then reinstall, it will install for Vegas 19 in:
    C:\Program Files\VEGAS\VEGAS Pro 19.0
    then Voukoder works for Vegas 19, but does NOT then work for Vegas 18.
    Is there a way to install the connector for BOTH versions of Vegas 18 and 19 at the same time? Or am I doing some thing wrong?
    Thanks!
  • Vouk 28. November 2021 um 19:24
    Yes.
    Copy the directory C:\Program Files\VEGAS\VEGAS Pro 18.0\FileIO Plug-Ins\voukoderplug and the file Voukoder-x64.fio2007-config to:
    C:\Program Files\VEGAS\VEGAS Pro 19.0\FileIO Plug-Ins\voukoderplug
  • Thanks Vouk for the quick response. I did this with one small tweak:
    Copied the directory
    to:
    Copied the file
    C:\Program Files\VEGAS\VEGAS Pro 18.0\Voukoder-x64.fio2007-config
    to:
    C:\Program Files\VEGAS\VEGAS Pro 19.0\Voukoder-x64.fio2007-config
    This worked for me.
    Thanks!
