GPU selection for NVENC does not persist
    We noticed that when configuring the NVENC encoder settings, the selected GPU does not persist. We are attempting the double check that we have the correct GPU selected and when doing so, the configure box appears to reset the value.
    We can confirm that the selected GPU is the one that is indeed used when "OK" is selected, not the one that shows when you go back into the configure screen. Please view the video for a better illustration.
  • Vouk 2. Dezember 2021 um 09:16
