The program doesn't render anything if I install a newer version of vegas-connector. The rendering window shows up and stucks with progress of 100%. However if I install version 0.9.10 of the connector, everything just works fine. I've tried it with every builds of VEGAS Pro 19 and every avalible versions of Voukoder.
Render doesn't work with any connector that is newer than version 0.9.10
2. Januar 2022 um 19:26 Hat das Thema freigeschaltet. -
What exact version of VEGAS are you using?
Right now it's VEGAS Pro 19 Build 458.
Sadly I can't afford a legal copy of the software. I use a cracked version of it. (Only for personal editing.) Could this cause the problem?
Strange I have the current connector working with 19.458 (and every other build of 19).
faszkoktel You might want to consider buying a licensed version of VEGAS. I don't support cracked software.
1. März 2022 um 08:54 Hat das Thema aus dem Forum Bug reports nach Closed bugs verschoben. -
I'll buy it as soon as possible. Thanks for the answers!
